engine plug and temperature sender questiion?? *DELETED*
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by chulisohombre, Sep 5, 2002.
  1. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    Post deleted by chulisohombre
  2. JIMs70K25
    JIMs70K25 1/2 ton status
    Dec 31, 2001
    524
    Chesapeake, VA
    Re: engine plug and temperature sender questiion??
    The newer engines with computers and smog stuff had the sender mounted in/on the thermostat housing. The housing was cast to except the sending unit. They also had vacuum switches mounted on the housing that were temp activated. Also the sending unit could be mounted on the intake manifold.
  3. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    You can mount the sending unit on the heads between 6 and 8 or 1 and 3. The heads are the same on both sides. If you remove the left head and put it on the right side the unit would be between 6 and 8 and vise versa.If you put the sending unit on the oposite side it is on now the only issue you should have is wire length.
    John
    John
  4. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    I added an Autometer water temp gauge, and I have the sender installed in that hole in the passenger side head.
  5. chulisohombre
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    i have the later engine cast thermo housing.so would this give me an acurate measure of temp to put the sending unit in there?
