Engine Poll
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MudNurI, Sep 10, 2001.
  1. MudNurI
    MudNurI 1/2 ton status
    Jul 15, 2001
    2,113
    VT
    Okay so the next major undertaking for "puke" is to replace the engine. We wont be doing this till spring, BUT with two little monsters, and a house, I need to start planning now. Currently I have the 305, I want a 454, hub thinks a 400 will do everything I want or need it to do. Because I have until spring -- money wont be the factor-- if you could put any engine in your rig, what would it be??? remember, I don't go off road... so its more for "show" thanks!
    1986 K5 4" skyjacker suspension 3 " body, 14 bolt rear,(sitting next to truck) 12 bolt (still in truck) dana 44 front, TIRED ol 305----
  2. Sparky87k5
    Sparky87k5 1/2 ton status
    May 6, 2001
    726
    Lynden, Washington, 4 miles from Canada
    Going 454 is costly due to engine costs, all new brackets for power steering, alternator, and A/C if you have it. New exhaust system, radiator eventually, and you end up with fuel economy that puts a grin on an Arab. If you were going to really need the power, go for it, but for show, verrrry costly.
    Stick to a 383 or 400 if you want street usable power and economy. Figure $1000 less than a BB454 to go small block power.
    87 K5, D60 & 14FF, 5 sp & NP208 & 383 stroker. Build it Bulletproof and take it fishing!
  3. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    LT1 or LS1 out of a vette/camaro. Since you are street only this will be perfect.
    The LT1 has a sensitive distributor so shouldn't be wheeled or washed.
    Dave
    Horn Broken... Watch For Finger.
    <a target="_blank" href=http://coloradok5.com/gallery/Daves-Pics>http://coloradok5.com/gallery/Daves-Pics</a>
  4. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    406. 406. 406. 406. 406. 406. 406. 406. 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406 . 406. 406. 406. 406. 406. 406. 406
    <a target="_blank" href=http://community.webshots.com/user/thatguydrew23>http://community.webshots.com/user/thatguydrew23</a>
  5. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    Hmmmmmm, I wonder what your next motor will be?!?!?![​IMG]
  6. fr8train
    Aug 2, 2000
    1,712
    Maryland
    DO I HAVE SOME PICS. TO UPLOAD FOR YOU MAN.
  7. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    chevy performance is putting alot of horses into thier crate 350s. keep some kind of fuel eff. and still be able to get up around 500 ponies.
    <a target="_blank" href=http://coloradoK5.com/gallery/Pauls89K5>http://coloradoK5.com/gallery/Pauls89K5</a>
  8. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    If money is not a factor, then why not the 502 fuel injected crate engine? You can get all the brackets from ebay, and most of the rest from summit racing.
    The only problem you'll find here is if you have a weak tranny or 10 bolt axles, it'll drown you with more expenses every time.
    <font color=purple>//////
    <a target="_blank" href=http://blazer79.freeyellow.com>blazer79.freeyellow.com</a></font color=purple><font color=black>
    Soon a 454 K5!!</font color=black>
  9. SlyDog
    SlyDog 1/2 ton status
    Oct 23, 2000
    3,035
    Scottsdale, Arizona
    ................... and hubby will have fun driving it too [​IMG]
    <font color=green>[​IMG]1977 K5 GETTIN IT AWN[​IMG]</font color=green>
    <a target="_blank" href=http://www.slydawg.rockcrawler.com>www.slydawg.rockcrawler.com</a>
  10. Storm Trooper
    Nov 24, 2000
    4,640
    Sorry but I'd go BIG BLOCK!
    If it's not a daliy driver, who cares about gas mileage.
    I really miss my big blocks. Nothing like a motor that shakes the ground for show. 454 or maybe a fuel injected 502?
    I've had some bad a$$ small blocks but then there is a BB. A whole nother class. I'd love to have a street blazer with a blown 454. Bet you could break some necks. Oh, don't forget to go one-ton first!
    [​IMG]<font color=red>[/b]"Rid'in HigH in my K5"[​IMG]
    ....[​IMG]<font color=blue>[/b]"8" Lift -<font color=purple>38.5's"[​IMG]....
  11. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Ramjet 350, VROOOM! Fuel injected and ready to run, for about $4,500, ouch! Well actually GM has a Vortec motor that puts out 330 horses right out of the box for $2,000. A complete version of that runs $3,000. A 454 is way too much of money eater to be any good. Parts are expensive, all your stuff needs to be swapped (tranny, doo dads) and horrible mileage. A 400 is a good motor but the blocks are getting rare and that motor is prone to cooling problems. I'd just build your own vortec 350 so you can have some fun and brag.
    <a target="_blank" href=http://www.geocities.com/bigkern76>http://www.geocities.com/bigkern76</a>
  12. MudNurI
    Jul 15, 2001
    2,113
    VT
    all of your reasons for not going with the 454 are the SAME as the old man's. $$$$ I think he is a little worried about the check book. LOL! Luckily for me, the 305 still has life in it. My original dream was the 502 crate, but he shot that down. He wants me to go with the 400. Even offered to do most of the work (what a guy). I figured him out however, he just wants to be the one in the drivers seat. The guy I got the blazer from has a 400, just waiting for a home. Luckily I have some time to plan, or save for that matter. I put hub's lift on the back burner for him. so nice of me! He has had the rancho 4" for over a year now in the garage, cant find anyone to do it, that has some sort of idea what they are doing. so I figure might as well spend more money on the Blazer!!
    IF ONLY THE 3 YEAR OLD COULD TURN A WRENCH
    1986 K5 4" skyjacker suspension 3 " body, 14 bolt rear 12 bolt dana 44 front, TIRED ol 305-
  13. NOT4SHW
    NOT4SHW Guest
    I think it would be real hard to beat a crate motor, you can't beat a 330HP for $2200.00 and it looks good. My dad just put one in his pro street s-10 and I'm wishing I would have gone that route because I will have about $1600.00 in my motor, maybe a few more HP but I won't have a 12 month warranty!
    Good Luck!
    '79 K5,13 1/2" lift, 39.5 TSL's,15x12 Eagles,350,t-350,warn 8274,39.5 Boggers for wheeling!
  14. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    i'm running a whooped old 400 with mild mods, and i love it. but the 3lbs of oil pressure is gonna bite my a$$
    Tork DSR
    I just got a winch, it takes the fun out of things.
  15. WOODYJ
    WOODYJ 1/2 ton status
    May 5, 2000
    144
    My vote is for an LS1 if you are going for street performance, mileage and allot of show. If money isn't the factor, I'd put my money there!!!!! That is my next powerplant!!
    k5woody I Don't Understand The Jeep Thing Either!!!
  16. shaggyk5
    shaggyk5 1/2 ton status
    1,610
    SE pennsylvania
    damn you bastard, I was just gonns mention my friend who has a "whooped old 400 with mild mods, he loves it. but the 3lbs of oil pressure is gonna bite his a$$"
    --matt
    <a target="_blank" href=http://www.geocities.com/shaggyk5>www.geocities.com/shaggyk5</a>
    <font color=red>SIGN MY GUESTBOOK!</font color=red>
  17. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    i would go with a 454 out of a late model GM truck. pay for the motor from GM dealership, or go to a wrecking yard. then the wiring harness and a few other tidbits. and off you go. well a computer or the trans to go with it too. but anyway. you dont need to do much to a stock EFI BB. but you can if you want to.
    Grant
    1974 Chevy Blazer Cheyanne. but it is on 33's now, with saggy old springs. i am in Yuma Arizona if ya got any parts for me.
  18. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    To be truthful why don'y you get a modified 350 with some good heads like Brodix or AFR's? From reading your posts and whatnot and if you don't plan to offroad it or Tow stuff why bother w/ a big cube engine for a daily driver? Do you enjoy buying more gas? A 383 and 400 both will tend to drink a bit more gas but really overall it depends of the entire setup you run. You also may want to think about going FI (TPI) or getting the Edelbrock MPI conversion. Those would better your drivability, give you more power, and milage too.
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://coloradok5.com/gallery/captcrunch>http://coloradok5.com/gallery/captcrunch</a>
  19. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Build a small block 415. 500 hp 500flb torque from a motor that weighs 500 lb. Total winning combo, big block power in a small package. Check out the possibilities at <a target="_blank" href=http://www.speedomotive.com>http://www.speedomotive.com</a>, I did!
    What, Me Worry?
  20. Blazer79
    1,816
    Do you mean <a target="_blank" href=http://www.speedomotive.com>www.speedomotive.com</a>?
