ENGINE PROBLEM
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MA87K5, Nov 10, 2000.
  1. MA87K5
    MA87K5 1/2 ton status
    Apr 6, 2000
    558
    Chicopee, Ma 01020
    When I'm traveling at around 30mph, and the gas pedal is depressed enough to keep the speed, the truck starts to buck. I can faintly feel it at high speeds. The engine even does it when the truck is in park and I gradually give it gas. I have replaced the fuel pump, fuel filter, plugs, wires, cap and rotor, I checked the coil and the ecm, map sensor, throttle position sensor, the sensor that sits on the side of the TBI. The timing is correct. I am stumped. Any help would be greatly appreaciated. Thank you.
  2. tRustyK5
    Jul 23, 2000
    36,170
    1,379
    E-town baby!
    Have you checked fuel pressure? If the fuel pressure is too low you will get a surge at a steady light throttle cruise. I seem to remember 9-12 psi being the tolerances, but I would be aiming for 12-14. I beleive the pressure can be adjusted on the throttle body itself but I've never done it.
    Rene
  3. dumbfounded
    dumbfounded 1/2 ton status
    May 20, 2000
    176
    Castalia, NC
    Sometimes the O2 sensor can cause this to happen change it they are relatively cheap. Also feel the exhaust pipe to see if it pulates then give it gas it should blow pretty hard (to check the cat). One more thing if your truck has alot of miles or even "hard" miles it could be the timing chain or a lifter. Maybe even a bad valve. A compression check can check the valves.
    Love, Peace, and Hair Grease...........
  4. mrivan
    mrivan 1/2 ton status
    Sep 10, 2000
    123
    Coastal Mts. Or.
    sounds like a fuel problem go to a garage with an exaust gas anilizer they can tell you a lot in a couple of minutes might be as simple as a plugged catilitic converter if theres one on it...
    Mrivan.....
  5. MA87K5
    Apr 6, 2000
    558
    Chicopee, Ma 01020
    The cat, and the O2 is about 30k miles old. It popped a code 33 a few days ago. The ECM checked out to be good. I'm going to replace the fuel pump since it has a lifetime warrenty on it from autozone it is an AC Delco one, I think. What else could be the prob if it isn't the pump? It only has 144,000 miles on it, but it was owned by a company before I bought it.
    I am all out of ideas.
  6. MA87K5
    Apr 6, 2000
    558
    Chicopee, Ma 01020
    Fuel pump is now ruled out. No change in problem. Maybe the injectors are bad at certain pressures.
  7. Tonyraca
    Tonyraca Registered Member
    Sep 28, 2000
    87
    San Jose, CA
    I don't know about your specific situation, but in my car I had a similar problem once, and it turned out that I had a bad spark plug wire and I had one cylinder misfiring.
    Tony's Rusty 79
  8. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Check the basics first, as mentioned above check all 8 of your wires, cap and rotor. Could also be a tank of bad gas, that is not unheard of.
    <font color=black>'79 - 406 TPI -<font color=orange> K5#5 - <font color=blue>See it at---&gt;http://www.blazzinor.coloradok5.com
  9. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    My '88 pickup is doing the same thing, and I believe that it is because of an exhaust leak that I have at the donut right by the O2 sensor (or the manifold might be cracked). This allows a little air to get to the sensor under light throttle, and even worse when you lift off the throttle abruptly. The air causes the O2 sensor to return a false lean condition, which makes the computer make the engine run real rich. I am procrastinating on fixing it, because all of the studs are going to break on the manifolds, and if I have to take the manifolds off, I am going to have to replace all of the AIR piping that is attached to them. I have had it apart once before, and I know it's not coming loose again without damage.
    Tim
    1970 Blazer CST 4X4 350 SM465 NP205
    1987 Suburban 4X4 350
    1988 Chevy Pickup 4X4 350
  10. MA87K5
    Apr 6, 2000
    558
    Chicopee, Ma 01020
    Can slightly clogged injectors cause this problem? They do have small drips with the fine spray.
  11. Blazer1970
    1,600
    Old Mission, MI
    I think that could be a possibility. My injectors are original at 170,000 miles. It seems like mine drip a little too, but it is hard to see. I did just rebuild the throttle body, and that didn't help much.
    Tim
  12. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Dont get a fuel pump from AutoZone unless you want to replace it every year. That is how my alternator is, and any otherparts you get there. get a good pump from NAPA or GM. The only things I buy from AutoZone now are oil, spark plugs, cleaners, basically anything thay didn't make or rebuild.
    90K5
  13. sosamantx
    sosamantx 1/2 ton status
    Aug 14, 2000
    393
    somewhere in Texas
    <font color=blue>Have you run a compression test? Maybe one cylinder is a little low. I would personally put in a good fuel system treatment, maybe some octane boost as well as some good gas and see what that does. Someone else mentioned maybe bad gas, it could also be moisture in the gas tank, there are additives for this as well. - Steve</font color=blue>
    <font color=blue>Steve Sosa a.k.a. "sosaman"</font color=blue>
    http://sosaman.home.texas.net/carpics.html
