Engine problems
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by shupach, Mar 10, 2001.
  1. shupach
    shupach 1/2 ton status
    Dec 28, 2000
    648
    Dallas, TX
    i'm building a 400 SB on a 76 K5, i need to take the oil filter off i broke my wrench trying, tried to use the one u hook up to ur impact gun, didn't work, i stabbed a huge screwdriver through it and it is still on, wat do i do?
    phill
  2. TheGeneral
    TheGeneral 1/2 ton status
    Feb 22, 2001
    556
    NC, USA
    Phill, 1st things first, when did you change you oil last man, cuz it shouldn't be on that tight, unless completly rusted together, which would be a first in a vehicle that has had oil running through it. Now back to the problem, I actually had a very smart friend break my wrench and crush his filter trying to get it off, and the funny part about it was, he forgot righty tighty, lefty loosey since he was under vehicle. So basically he tighted it as tight as possible. It still backed off once he got the principles down. How to get yours off if it is really that tight, two ways, one experimental and one sure thing. Experimental (I have used it for some bolts) is to freeze it with freon, about a can, and see if it will loosen it up, the other is just cut the filter away down to threads and clean them out with wire wheel. I'd try to figure out what caused it, and maybe install a remote filter (maybe the heat is getting to it) Good luck, and it sure makes me feel good hearin about other's funny troubles.
    If you ain't hurt, you ain't playin' hard enough.
    The General
