engine problems
Discussion in 'The Garage' started by bigbadchev84, Mar 14, 2005.
  1. bigbadchev84
    bigbadchev84 1/2 ton status
    May 17, 2004
    2,191
    Hermiston, Oregon
    ok well i have been working onmy motor for awhile now off and on, this weekend i finally got a welder so i could weld up the exaust, i had blew a head gasket on break-in of a completely brand new engine. well i got it all done yesterday and i couldnt get it to idle smooth, it has been balanced and everything. i played with the timing forever and still no difference, i got out the carb cleaner and started spraying around the vacuum fittings and carb base, when i got to the egr block-off plate it made a wierd "pop" noise and started idleing perfect imediatly afterwards and it has been since, i got to looking a little closer and found the aluminum block-off plate was cracked, and one of the intake bolt heads is broken off, might have been the wierd poping noise i heard? i am going to pull the intake, and replace the bolt and new gaskets, would there be a problem with using 1/4 plate to replace my block-off plate??? also after spraying the carb cleaner and everything running smoothly now, should i be concerned that it all the sudden started working perfect??
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Can't answer the popping and running question .
    But as for using 1/4 inch plate , I don't see why not .
    I have ran the factory spacer with the holes and a simple piece of sheetmetal before to block off the EGR with no leaks etc ( Had to borrow an Edelbrock 4 years ago and EGR hit that carbs rear pass side ):k5: :k5:
  3. bigbadchev84
    May 17, 2004
    2,191
    Hermiston, Oregon
    ok well i took the intake off this weekend to take out the broken bolt, i found one of the pushrods had poped off of the lifter, that must of been the wierd popping noise i heard, it hitting the underside of the valve cover. what would cause this? why did it run so good after this popped off?
  4. bigbadchev84
    May 17, 2004
    2,191
    Hermiston, Oregon
    ok up to date now, i pulled the valve cover to find that the rocker arm had actually broken off, ok so i replace the lifter, rocker arm, and pushrod and this thing is back to running like crap again, this is driving me insane! what is going on here? this is a brand new motor! could this be a flat cam lobe or what? please help!!!
  5. Big Red
    Big Red 1/2 ton status
    Jan 9, 2003
    250
    Bristol, CT
    how long did u do the break in routine? when i had my motor rebuilt i waited 700miles before even thinking of touching th go pedal hard. i don't know why it would run great with a broken rocker other than the valve wasn't sitting in its seat all the way. :dunno:
  6. bigbadchev84
    May 17, 2004
    2,191
    Hermiston, Oregon
    i blew a head gasket while breaking the motor in, it has zero miles on it, i just got the motor in, blew the head gasket, i have had nothing but probs with this motor!, i have built about 10 motors completely and this one is the first one to ever give me fits like this
  7. dirtwarrior17
    dirtwarrior17 Banned
    May 14, 2004
    1,820
    Redding, CA
    wow.... call ripleys... i don't know what could cause it run good without one valve then like crap with all of em working, doesn't make sense.
    since you've built 10 motors im sure you know about the timing advance wire.
    Can't think of anything else.
  8. teamhickman
    teamhickman 1/2 ton status
    Aug 28, 2004
    226
    Buckeye, AZ.
    Pushrod length correct? Hydrolocked lifter?
  9. dirtwarrior17
    May 14, 2004
    1,820
    Redding, CA
    I just thought of this... are you sure its not a bent valve? blowing a head gasket could easily get it hot enough to bend one. My dad had one bend on his 383 when it was pingin and it ran like **** after it bent. If thats the case i can understand the broken rocker and runnin like ****.
  10. bigbadchev84
    May 17, 2004
    2,191
    Hermiston, Oregon
    ok just a thought here, it could very well be a bent valve i didnt think of that, but in theroy when the intake valve rocker on the #3 cylinder broke and the engine smoothed out and idled good, that would be a dead cylinder. well now that i fixed the rocker and it runs like crap again, couldnt i pull the #3 plug wire and kill the cylinder, just to double check?
  11. dirtwarrior17
    May 14, 2004
    1,820
    Redding, CA
    be a good idea... i would bet money thats the problem... i can't see how anything else would do that.
