Engine Probs
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by k5freak44, Sep 8, 2005.
  1. k5freak44
    k5freak44 1/2 ton status
    Jun 1, 2004
    2,164
    Plano, TX
    Hey guys, im running a 350 TBI engine in my 91 and i have been having some problems with the recently. Its got 103,000 on the clock and it has ran strong until a couple of moths ago.
    I started noticeing A big puff of white smoke on startup ONLY. It dosent smoke after the engine is warm.
    Coolant in the resavour is dirty and very low.
    When i have my rear window down and im crusing at about 45 there is a real bad smell that is sucked up into the cab. Im guessing its coolant burning because it smells sweet. But it is not smoking when i smell this.
    Also when my engine starts up sometimes it stubles and it isint uncommon for it do stubmle and die when i put it into gear.
    Also starting yesterday, after i start my truck up and start driving, the power suts off for a second but it dosent stall. Just my radio turns off when the engine kinda stumbles.
    What am i up against here. I have been told i probably have a bad head gasket, but i figure i would get an opinion from the pros.
    -Jonathan
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Its broke :p:
  3. 88sub4x4
    88sub4x4 1/2 ton status
    Sep 22, 2002
    792
    Long Island, NY
    Sounds like a coolant ingestion (sp?) issue to me, but further diagnosis is needed before blaming a head gasket or head. Intake leaks could also produce coolant injestion.
    If you run the engine with the radiator cap off you may be able to see a steady flow of air coming out the radiator. This would eliminate an intake coolant leak, and generally means a head or head gasket issue.
