engine pulley?'s
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by baldbandit, Jun 24, 2001.
  1. baldbandit
    baldbandit 1/2 ton status
    Jun 16, 2000
    282
    Marshall TX
    engine pulley?\'s
    I'm converting my 6.2 diesel to a 350 small block. My parts truck has a 305 small block. I'm using the long AC compressor ( 6.2 came w/ long AC compressor). I'm using brackets like what came on my 78 blazer ( also has long compressor) for my engine so that i can keep the long AC compressor. My question is, can I use the pulleys from the 305 on my 350. There is some difference in the pulleys. My 78 blazer (350 engine) pulleys are different from the 85 (305). On the water pump pulley, the blazer has a large 1 belt outer pulley w/ a smaller belt pulley behind it. The 85 305 water pump pulley is one piece and has both belt pulleys the same size. The 78 blazer crank pulley also has the outer belt pulley larger than the two inner belt pulleys. The 85 305 has all three pulleys are the same size as the large pulley on the blazer. make any sense?
    thanks
    baldbandit
    "Have you outdriven a F**D lately?"
    Check out my site!
    <A target="_blank" HREF=http://www.baldbandit.coloradok5.com>http://www.baldbandit.coloradok5.com</A>
  2. baldbandit
    Jun 16, 2000
    282
    Marshall TX
    Re: engine pulley?\'s
    ttt
    Check out my site!
