engine question ? where did mine come from ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by scrappyk5, Apr 30, 2002.
  1. scrappyk5
    scrappyk5 1/2 ton status
    Mar 17, 2002
    2,099
    virginia
    when i bought my 84 k5 , it originally came with a 305, but the guy said that the previoius owner put another motor in it. well
    i finaly was able to read the casting number on the driverside rear and i came up with 14102058. well i went to the mortec chart and it said its a 305 from 87-91. well i am pretty sure that this guy plucked this out of something, just dont know
    what , any ideas ? and how can i find out the specs. as far as hp and torque and all the other info like inside stuff?
  2. dyeager535
    26,975
    Use mortec to get the location of the suffix code, write that code down, then go to www.nastyz28.com and check that against those suffix codes. It will tell you EXACTLY what vehicle it came from, and what HP rating it was.
  3. gtkustoms
    gtkustoms 1/2 ton status
    Oct 6, 2001
    281
    nm
    my book says its from an 87-88
    305 2 bolt mains
    and anywhere from 150 to 190 hp
    the 190 hp is from a firebird
    could tell you alittle more with more codes
  4. scrappyk5
    Mar 17, 2002
    2,099
    virginia
    thanks, yes i am wiping off the grime so i can read the other numbers. i had to practically brake my neck to read the one in the back.
    the engine was installed witht the original qaudra jet carb from 84 with all the v belts . it feels like a awful lot of power to only be rated 150hp , so i will try and get more numbers
