Engine Question!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by rich'90, Jul 8, 2001.
  1. rich'90
    rich'90 1/2 ton status
    Feb 27, 2000
    159
    Savannah, GA
    I know you guys don't like jeeps but I just rebuilt the old 350 out of my blazer(after I put a 383 in) to put in my wifes jeep. I put together the long block kit 383 and had no problems but this old engine is killing me. It runs but one exhaust is hotter than h@ll. It has dual exhaust and the even side is so hot I can't even put my hand there, the other side is cool. #8 is running hot and lean I think but I don't know why. Anyone have and suggestions? This is eating me up and I won't be able to sleep tonight if I can't figure it out.
    Thanks for any help.
    Rich
    Go heavy or Go home[​IMG]
  2. CCRider
    CCRider 1/2 ton status
    Jul 8, 2001
    314
    Charlotte North Carolina
    Do you still have the original TBI off your 90 Blazer on it? Sounds like a fuel distribution prob. What else did you change or mess with?
    1991 Fullsize 5 1/2"lift, 37"ssr's,10Bolt8 lug , 14Bolt ff, 4:56 Detroit rear, 12"fr. 14"r Bilstein remote res.350 P.F.I , 700r4 , 241c W/ sye
  3. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Whats on the engine, FI, heads, cam, etc....
    <A target="_blank" HREF=http://www.geocities.com/bigkern76>http://www.geocities.com/bigkern76</A>
  4. rich'90
    Feb 27, 2000
    159
    Savannah, GA
    got a q-jet from the yard and rebuilt it. Other than that and the different intake manifold, everything is the same from the stock 350 from a 90 blazer.
  5. CCRider
    Jul 8, 2001
    314
    Souds like a fuel problem , or a vacuum leak of the intake gasket sucking air (it wouldn't take much), do you have any body you can swap carbs with, perhaps try a holley ? Q jets can be very finicky and sensitive to debris (that french guy!) but seriously you need a good filter on it from the time you fire it up or crap gets in those metering rods and passages!!
  6. rich'90
    Feb 27, 2000
    159
    Savannah, GA
    I thought it might be a leak on the intake also or the head so I replaced the gaskets on that one head and the intake. Pretty damn sure I did a good job this time and still the same problem.
  7. rich'90
    Feb 27, 2000
    159
    Savannah, GA
    Just to keep you guys up-dated in case anyone else has this problem. It turned out to be a combination of timing and valve adjustment. I was getting poor compression on the odd side because the valves were not closing. That head was adjusted by.....we will not mention any names(wife). So the even side was picking up alllllll the slack and running hot as sh(t. Anyway, it is fixed with the help of a compression tester and a couple of buddies.
    Thanks for the help!
    Rich
