engine question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by rodriscoll, Jun 20, 2003.
  1. rodriscoll
    rodriscoll Registered Member
    Feb 7, 2003
    18
    Townsend, MA
    I have a 76 Blazer with a 350 but what is odd is that my motor has no hole for a fuel pump on the block and has an electric fuel pump on the passenger side frame rail this truck has 73k original miles and has a new edelbrock carb can anybody shed some light on this does not seem normal for a 76.
  2. dyeager535
    26,979
    What is the casting number on the back of the block, or the suffix code (if present) behind the alternator on the block?
    Sounds like a much later block, or something entirely different /forums/images/graemlins/smile.gif
  3. monte0172
    monte0172 1/2 ton status
    Sep 16, 2002
    182
    Memphis, TN
    Is the dipstick on the left or right??? If its on the passenger side then its a later model block and is not original.
