engine rebuild help
Discussion in '1982-Present GM Diesel' started by odee1, Jan 18, 2005.
  1. odee1
    odee1 Registered Member
    Feb 27, 2004
    50
    I have found two good 599 blocks that will clean up to work with standard pistons both were low mile motors that had cracked heads or pistons. The cylinder bores look and measure out good. I have a set of pistons from a later model pin spray block that are in good shape. I have checked the pistons out for wear and started fitting them to the new block. Will it be okay to use a pump from the later pin spray block. The pump may have 4 or 5 hundred miles on it before the blocl developed water leaks. I plan on using the cam and lifters from this engine also. I will be putting a turbo on this also. Will anthing be gained in the cylinder heads if I put the larger valves in it from the earlier 6.2j heads? I want to have a solid engine when I'm done will pull a jeep and drag car some with this truck. thanks
  2. AgDieseler
    AgDieseler Certified Scrap Producer Premium Member GMOTM Winner
    Jan 25, 2001
    1,044
    1,115
    Dallas
    The pump from the spray block will be of the DS4 electronic variety, so you'll have to have the 'puter and harness to match.
    Just go back with the regular valves. Nothing substantial is gained from the only slightly larger valves other than a greater tendency for the heads to crack in between the valves.
  3. odee1
    Feb 27, 2004
    50
    thanks, I may have the injector pump traded for some parts I need on another project. What about the oil pump in the engine? It was replaced also before I got the engine.
  4. AgDieseler
    Jan 25, 2001
    1,044
    1,115
    Dallas
    Oil pumps are fairly cheap. Unless you're 100% sure that it's brand new and working perfectly, I'd change it. You've got it apart, and now is the easiest time anyway. Just be sure you get a genuine GM one, and you'll be fine.
  5. odee1
    Feb 27, 2004
    50
    anybody else got anything to put into this? I would hate to see my first diesel rebuild go bad. Any items to pay extra attention to?
  6. Steve_87K5
    Steve_87K5 1/2 ton status
    May 26, 2000
    521
    central NC
    I'm doing the same thing....building up a 599 6.5 from salvaged engines.
    Maybe someone who knows could clarify what all the stampings on the bottom of the block means. I know some of them relate to the piston sizes which were fitted at the factory. I think some also relate to the size of the crank bearings. GM offers different size main bearings to get the oil clearance just right.
    I have salvaged 5 engines from dealer dumpster diving, and saved all the parts which looked OK. (I got permission first)
    So I have a collection of precups, with 4 different sizes and shapes of holes. The largest is about 9/16" out of a '93 TD. The smallest is about 3/8" out
    of an '83 6.2
    I have heard that the small cups are better for economy. Maybe they'll fit
    in the later heads, I don't know yet.
    One thing I'd like to do at this stage is drill/tap the block for a relocated water jacket drain on one side. The boss on one side appears to accomodate a relocated drain (the engine block drain on one side is inaccesable because it is behind the engine mount). Anybody done this?
    The '83 block I salvaged had the cooling passage around #8 totally blocked with crud. I cleaned it out by putting some 1/4 steel tubing in my pressure washer and sticking it down in the head bolt holes. No wonder the head cracked at #8.
    I started spending money on my project with this '83 6.2 block before I was aware of the stronger 599 lower end. Since the '83 will be built (now at 030 over) for economy, it should stay together. I bought new pistons and had the rot. assy balanced so far.
    Any assembly tips for making the bottom end on a 6.2 (non599) block
    stay together over the long run? Balance for sure is the main thing.
  7. tRustyK5
    Jul 23, 2000
    36,184
    1,392
    E-town baby!
