engine rebuild
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Taz, Jan 31, 2001.
  1. Taz
    Taz Registered Member
    Dec 31, 2000
    77
    SE Wisconsin
    has anyone used a product called "glyptal" it surpossed to coat the pores of the engine and let the oil 'flow' better
    it is sold by Eastwood Co. part # 46000z
    www.eastwoodco.com/cgi-bin/sgin0101.exe
  2. Wheels
    Wheels 1/2 ton status
    Aug 18, 2000
    638
    You can do the same trick with Rustoleum rusty metal primer brush on type. Glyptal is a product I use in electronics to put on adjustable resistors, capacitors, etc. to keep them from moving after I adjusted them. Rustoleum will work just as good (if not better) and not come loose if the engine is degreased. It's also alot cheaper. There are several engine builders that use Rustoleum. My .05.
  3. Taz
    Dec 31, 2000
    77
    SE Wisconsin
    thanks for the info
