engine restore
Discussion in 'The Garage' started by 85 Jimmy, Sep 24, 2006.
  1. 85 Jimmy
    85 Jimmy Sheepdog Premium Member
    Dec 31, 2005
    1,913
    69
    Gulfcoast
    anyone ever use the engine restore junk???
    my motor is pretty worn out and tends to smoke alot, i have a new motor but am waiting to put it in till i have everything for my TPI swap
    well i guess the question is, does that junk work???
  2. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    from what i have hurd it will hurt more in the long run then it helps, but since your swapping out motors, you dont care, it might help a little for some of your problems
  3. darkshadow
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
  4. darkshadow
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
  5. darkshadow
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
  6. badmix
    badmix 1/2 ton status
    Nov 7, 2004
    4,205
    60
    West Virginia
    I have mixed thoughts on it. I once talked to a mechanic that said to put restore or any engine additive in b4 you change the oil. What will happen is, the oil filter may actually capture the thicker additives and not actually allow them to work thru the motor and will clog the filter. When the filter is clogged, there is a bypass, that is why you would wanna run it right b4 ya change your filter and oil. To allow the additive to actually work thru the motor. Weather this is truthful or jus some random thoughts, I have no idea. Ive used it, but honestly couldnt tell if it helped or hurt. I havent seen anything work in motors, except Marval Mystery oil for sticky lifters.
  7. RedBrute
    RedBrute 1/2 ton status
    Sep 22, 2002
    346
    Southern tier New York
    I have used it with good results. The vehicle is a Jeep Grand Cherokee with the 5.2 V8. When I got it it had 92K on it. Used 2-3 quarts of oil between changes, every 3-4k miles. Before taking it on a trip to Florida I added Restore during an oil change. Used 1 quart down and back... I've been using it every oil change ever since, Jeep has 162K miles on it now. I believe in the stuff. I've also tried going without it, oil consuption goes right back up without restore.
  8. 85 Jimmy
    Dec 31, 2005
    1,913
    69
    Gulfcoast
    so i guess as long as i continue to use it it'll work
    the only reason i'm even worried about it is b/c it get's alittle embarrasing when i pull up next to a hot girl with her windows down, then i pull away and i blow alot of smoke right into her window...
  9. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,229
    486
    New Hampshire
    I use the stuff, and haven't really noticed any difference. I think I am getting more smoke on startup now. Maybe i need to change my oil again?
  10. twodollars
    twodollars Registered Member
    Jul 19, 2006
    49
    Wayne, MI
    Most of those type of products, ie, those that "reduce oil consumption" are usually just a load of viscosity improvers, which is part of the normal oil additive package. Will it reduce oil consumption? Probably - as the oil becomes thicker than without it, its harder for it to pass by the rings. But there is no magical resotration process occuring. In my job I have tested various oils, petroleum based and synthetics, and some aftermarket additives. I didn't find any reduction in wear using the additives.
  11. mike n
    mike n 1/2 ton status
    Oct 9, 2003
    101
    New York
    Imo all those additives are nothing more than snake oil.
  12. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,992
    130
    IIRC, Restore has metal in it which is there to help "reseat" the rings but seems like it could damage all of the engine bearings. Don't know if this is true, but one of the things I have heard...
  13. diesel4me
    Jul 24, 2003
    17,553
    939
    Massachussetts
    From the label...
    "RESTORE" contains "CSL"..particles of copper,silver,and lead,that fill in scratches in cylinder walls...
    I've seen the insides of two motors that blew not long after "RESTORE" was added..it looked like a tube of that "Aluma-Seal" radiator stop leak had been poured in the oil,and all over the engine's insides..it was all "glitter",and many parts were scuffed up like they starved for oil..I used it once ,never again!..:eek1:
