engine runnig crapy
Discussion in 'The Garage' started by chebywanna, Oct 11, 2003.
  1. chebywanna
    chebywanna 1/2 ton status
    Apr 20, 2003
    277
    streamwood, (chicago)
    this is a none truck question but still motor problem
    vehicle- 87 riviera, one of them first distriubutor less fuel injected vehicles
    problem- runs rough when cold, fine when getting to operating temp, starts dieing out (but doesn't stall) for one sec, runs fine for five or so and dies out again, and back to normal at normal temp. on low throttle it seems to missfire constatnly and shakes a lot (as if it was loading up) but once over 2200? rpm its perfectly fine.
    history- the motor is a "new" one, or reather moved from another, unknown milage, and its been that way day one (all though sat for a year) spark plug wires were just replaced, and ran a bottle of fuel injector cleaner throught the system.
    any ideas?
    thanks
    jim
  2. blaz72
    blaz72 Registered Member
    Oct 7, 2003
    28
    connecticut
    Might be bad coolant temp sensour.
  3. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    possible, TPS, CTS, O2 sensor...etc
