Engine running funny
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by damn90blazer, Sep 19, 2002.
  1. damn90blazer
    damn90blazer Newbie
    Aug 29, 2002
    i have a 90 350 TBI. the engine seems to idle real rough. gets to running temp real quick. and seems to not have any
    power after the initial off idle acceleration. its getting like 9 miles to the gallon on the highway and when i hit the gas
    it emits a horrible odor and when i let off the smell changes but its even worse. ive changed the distributor, coil, plugs
    and wires. have MSD dist and coil and bosch +4s ive also changed the throttle position sensor, map sensor and
    the knock sensor. i think the truck may be running too far advanced. any ideas? my next step is to replace the
    ECM and the ESC module.
  2. RESTORE89
    RESTORE89 1/2 ton status
    Jan 31, 2001
    548
    CHAS SC
    bad smell could be a clogged catalytic converter
    would also cause all the other symptoms
  3. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Also the IAC sensor is probably bad. That would explain the bad idle, and they seem to not work too well after all these years and miles. Its on the side of the TBI, cost aobut $35
  4. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    Have you changed the O2 sensor? If its a nasty egg fart smell your cat. conv. needs to be replaced.
  5. TIGHTWORK82 K5
    TIGHTWORK82 K5 1/2 ton status
    Oct 21, 2001
    140
    orlando , florida
    what about a bad head gasket ;burnin anti freeze smells pretty bad. try compression check.
