Engine running like **** again, Plez help
Discussion in 'The Garage' started by socal chevy, Jan 29, 2005.
  1. socal chevy
    socal chevy 1/2 ton status
    Nov 18, 2004
    308
    San Clemente, CA
    :1zhelp: My 305 is running like crap again. Ok heres the deal. About 2 weeks ago I wanted to conquer my engine running crappy problems, so I Checked the timing (good), Changed all ......spark plugs, New distributor cap/coil/rotor(was old and crappy), Checked firing (good), checked compression (good), Fixed a vacumm leak I found (T-fitting broke) ETC... Well after I did that I was stoked because the engine seemed to be running pretty decent. Well that was until today. I started it up and it sounded fine, but as soon as I took off and tried to give it gas, it would completely "bog"/ "lag" out, NO power whatsoever.I even try to give it full throttle, and NOTHING happens... So I drive it down the street (not able to go over about 15 mph) and pull over. I shut the engine off, and check everything out, (everything seems normal too me). SO I start it back up, and still doing it just as bad. So I give it full throttle again to see what happens (:grin: ) And it lags/ "bogs out" for about 2 seconds and then all the sudden kicks in and takes off.... WHAT THE HELL IS GOING ON?!!??!:confused: I am trying to get this truck running decent so I can start lifting/modding the thing out, but I want the motor to run good before I dump all that money. Someone please help, I dont know what else to do :frown1: . I need a good hint on what to do, or even better, I need an expert to come check it out! Thanks. :1zhelp:
  2. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    fuel filter? fuel pump goin out?
  3. ryoken
    Jun 13, 2003
    29,622
    1,374
    Jersey Shore
    definitely sounds like a fuel issue...
    do the obvious first, filter.. run a gauge inline and check your pressure.. if both check out, its probably in the carb (assuming its a carbed truck), bad accelerator pump, sludge in the bowl, etc...
  4. dirtwarrior17
    dirtwarrior17 Banned
    May 14, 2004
    1,820
    Redding, CA
    my brothers jimmy was doiin that (especailly when he floored it) when the o2 went bad. It would sputter for a second or two then take off. Could be the fuel. If all the fuel system checks out you might want to get yours hands on win aldl if its a efi 305.
  5. ryoken
    Jun 13, 2003
    29,622
    1,374
    Jersey Shore
    i doubt its efi if its an 84.....
  6. dirtwarrior17
    May 14, 2004
    1,820
    Redding, CA
    << needs to read sig
  7. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    I think your reading my sig, and not socal chevy's :)
  8. socal chevy
    Nov 18, 2004
    308
    San Clemente, CA
    Well, I replaced the fuel pump and it still runs like I described.. Actually I cant even give it alot of gas in park without it dying. It wasnt like that before I changed the pump. :confused: What now...carb?
  9. flatline
    flatline 1/2 ton status
    Sep 9, 2004
    167
    Cincinnati, Ohio (area)
    I am having the same problems with my 305 right now, runs great when it's warmed up and shutoff, I believe the carb is in need of a rebuild. I am considering the Holley Truck Avenger with a new fuel pump and dual fuel filters and pressure gauge since I am running dual tanks I may drop them empty and clean them out too before installing all the new stuff.
  10. hunterguy86
    hunterguy86 1/2 ton status
    Jan 10, 2005
    2,477
    San Marcos, Texas
    My 86 k5 was doin just what u described so i decided to rebuild the quadrajet. When i pulled the carb off i found that the gasket between the carb and the intake manifold was cracked. I went ahead and changed it and rebuilt the carb and now she runs like a champ. Im not sure if this will help you, just lettin you know what happened in my case.
  11. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    It kinda sounds like you had a bit of crap wedged between your needle and seat, which forced too much fuel into your carb. Sometimes shutting off and restarting the truck can flush the offending picec out.
    Are you getting a strong smell of gas from your exhaust? Black smoke out of the tailpipes? Those are sure signs your truck is running way too rich.
    You may also have a clogged cat converter, but generally they become a nuisance far before this stage of poor performance.
  12. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    If your running the stock air cleaner you might want to make sure the fresh air door is opening when the truck has warmed up. Doubt that would cause this much of a problem but it's one of those things people rarely look at.
  13. socal chevy
    Nov 18, 2004
    308
    San Clemente, CA
    Im looking into rebuilding my carb. I need to pass smog and i cant even drive it there!
    Got any pics of your truck? I got a 84' 305....plan on doing what u got....lemme see :D
  14. socal chevy
    Nov 18, 2004
    308
    San Clemente, CA
    No, no gas smell, and no black smoke.... And the Converter isnt even there. :)
  15. AkMudr
    AkMudr 1/2 ton status
    Dec 30, 2004
    917
    Alaska
    I was pretty retarded when it came to Qjets but I broke down and rebuilt mine a few weeks ago and its runnin tits now since I fixed the choke issue. Really it wasnt as difficult as I thought it was going to be.
    Ive been hittin 14mpg if I keep my foot out and performance is definately back. There is a Qjet book some folks here have recomended, hopefully someone will chime in and remind me.
  16. diesel4me
    Jul 24, 2003
    17,540
    935
    Massachussetts
    Check it out!!
    Have you tried hooking a vacuum gauge up to it,to see if you have low vacuum??--It could still be a vacuum leak,as the other poster said,the carb base gaskets often crack or burn out,that will cause hestation(and should kill your idle too!)...there are many other things besides lack of fuel that can do what your describing--
    a bad pick up coil in the distributor can do it,so can a bad accelerator pump in the carb--to me it sounds electrical,if it will run good sometimes and not good at other times--a fuel or carb problem would likely be there constantly---your EGR valve can make it bog out if its openning at the wrong time,or sticking open slightly--even an ignition module can do it too,it has a dwell advance curcuit in it,if that part of it craps out it can still run,but poorly-
    -I use GM modules only,many "cheapies" dont even have that curcuit in them at all!--the pick up coil isnt much fun to change,you have to pull the distributor out and take the shaft out--so many of them stay in the vehicle till death do us part--and they can drive you bonkers with their erratic symptoms--I have seen some run good for days,then act up every day for a week!--the wires on them get twisted every time the vacuum advance moves the pick up coil to advance the timing--after many times the wires break inside the insulation,making poor contact at times,its hard to diagnose a bad pick up coil--replacing it is not expensive,and even if it wasnt the problem,if its got a hundred thousand miles on it,its best to scrap it,it will give you greif sooner or later..
    You might have less than 12 volts getting to the big pink wire on the distributor too,if you dont have full voltage there it will have weak spark that will snuff out upon acceleration or heavy load,like pulling up a hill...there are lots of things to check--look for a gas filter in the carb that hasnt been changed,or any "universal" ones in the line hidden away under the truck that might be plugged---a kinked or collapsed fuel line can cause fuel starvation at times intermittantly too....Keep looking,and good luck!!:crazy:
