ENGINE RUNNING RICH
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by KILLERK5, Oct 26, 2000.
  1. KILLERK5
    KILLERK5 1/2 ton status
    Oct 19, 2000
    108
    Aurora, Colorado
    MY "SERVICE ENGINE LIGHT" KEEPS LIGHTING UP WHEN IM ON THE THROTTLE FOR TOO LONG. THE CODE IS A 44, WHICH IS THE O2 SENSOR IS INDICATING LEAN EXHAUST. I REPLACED THE O2 SENSOR, BECAUSE I RAN A VOLTAGE TEST ON IT AND IT FAILED. DOES ANYBODY HAVE ANY SUGGESTIONS ON WHAT ELSE TO CHECK?
  2. rich'90
    rich'90 1/2 ton status
    Feb 27, 2000
    159
    Savannah, GA
    Try the MAP sensor.
    Go heavy or Go home[​IMG]
  3. captaink5
    captaink5 Newbie
    Oct 31, 2000
    you need to hook up a vacuum gauge to the manifold and see what kind of vacuum you have. the cam shaft may be bad. I had the same symptoms in my 90K5, and that was what I found. good luck the captain.
  4. captaink5
    captaink5 Newbie
    Oct 31, 2000
