Engine running rough, help.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Doug, Oct 19, 2001.
  1. Doug
    Doug Registered Member
    Sep 1, 2001
    56
    Northern Colorado
    Other than the other problems described under "Qjet question", today on the way to work, the engine started to buck slightly and felt like it was bogging down. I took the trans out of overdrive and put it into drive and with the higher rpms, it seemed to help the situation. I drove like this for a little bit, then put it back into OD and not long after it started again. Vacuum line, running too rich, choke, computer, ??? I plan on swappiing the computer controlled carb to an older style this weekend, but right now I just need to make sure this thing will make it home(1 hr drive).
    '85 K5, 350, 700r4, np208, 10 bolts, as of 10/2001; wish list is extensive.
  2. Burbinator
    Burbinator 1/2 ton status
    Sep 14, 2001
    898
    Tempe, Arizona
    I've got my 12 gauge out...PULL!...
    Spark plug wire arcing to ground or a neighboring wire perhaps? I had a similar problem on a car I had in college. Just my $0.02
    The learning curve is a toll road...ride with someone who has already paid!
    <a target="_blank" href=http://photos.yahoo.com/abshort1>My Naval Fleet</a>
  3. Doug
    Sep 1, 2001
    56
    Northern Colorado
    No one?
  4. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    You sound like the same thing I have right now. I have an '81 and I've unplugged the lock up convertor, changed advance, modulator, and fuel filter but to no avail. I have TH350 but have to drop it down into 2nd and let rev before shifting up into third. Does yours shudder and sputter if you pull a hill with it?
    <a target="_blank" href=http://www.geocities.com/bigkern76>http://www.geocities.com/bigkern76</a>
  5. Dip Stick
    Dip Stick Registered Member
    Oct 14, 2001
    73
    Murdock, Florida
    When mine starts doing it I'll let you all know :)
    <font color=red> It's not what you drive, it's how you drive it</font color=red>
    1986 K20 & Lots of Rust
