Engine #'s
Discussion in 'The Garage' started by BurbLover, Aug 1, 2003.
  1. BurbLover
    BurbLover 1/2 ton status
    Jul 31, 2001
    3,060
    SW Missouri
    Engine #\'s
    I have my BBC on a stand in my garage, but having trouble seeing the #'s. Where exactlty should I look on the engine and once I get it, how can I get OEM info about it (original vehicle, year, etc)? Thanks.
    EDIT: It's amazing what a flashlight will do!!! Anyway I found the following info/#'s on it:
    Bellhousing:
    3999290
    CONV 1
    GM9
    I 20 71 (Found out means Sep 20, 1971 production date)
    Front Pass Side of Block:
    CE358413
    So, can anyone decifer this for me?
    Thanks!!
  2. dyeager535
    26,979
    Re: Engine #\'s
    mortec
    Suffix code should tell you what you want to know.
    nastyz28
    Will help you deceipher your suffix code. I *thought* that number you listed last (CExxxxx) would be it, but don't see CE listed.
  3. BurbLover
    Jul 31, 2001
    3,060
    SW Missouri
    Re: Engine #\'s
    Okay, let's see if I'm on the right track. I got this from the MorTec site:
    3999290....396.......68-69...2 or 4 bolt, Truck
    3999290....402.......70-72...2 or 4 bolt, Truck
    3999290....402.......72......2 or 4 bolt, Passenger
    I also found "CE" as a suffix code means "Crate Engine" or "Chevy Engine". This was used when the engine was either a warranty replacement or an aftermarket purchase.
    I guess it's time to go back to Checker & find the correct water pump based on this info.
  4. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Re: Engine #\'s
    HA! Thats pretty funny, my 402 is the exact same casting # and production date. Except mine was made in January '71. Cool $hit. /forums/images/graemlins/thumb.gif
  5. BurbLover
    Jul 31, 2001
    3,060
    SW Missouri
    Re: Engine #\'s
    KidJethro,
    Maybe you can help me out. I can't seem to find the correct short water pump for this. Do you have a short or long & what year/vehicle do you use when you get parts?
    I am assuming that since the casting #'s are the same that the blocks would be identical.
    Thanks.
