Engine Selection
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by sickquad, Aug 7, 2003.
  1. sickquad
    sickquad 1/2 ton status
    Jul 23, 2003
    785
    Ma
    So, It is time for me to pick a motor. I have a 85 Blazer, running 33's. The truck will be a daily driver and I will be taking it offroad frequently. The wheeling we do around here is mostly trail riding. Where a limited slip and 33" mud terrains are necessary.
    My question is if anyone has any experience with the stock GMGoodwrench motor for my truck.
    These are my options:
    1971-1985 Lt Dty Trks 350 (LM1) New Goodwrench Engine # 10067353
    or
    1987-1993 Lt Dty Trks 350 (L05) New Goodwrench Engine # 12520270
    Does anyone know anything about these motors? Would they be considered weak replacements? Do you guys know the horsepower ratings? The local GM dealership doesn't know
    My other alternative is the 330 HP #12486041
    Thanks for any info you may have.
    Chris
  2. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    If you're gonna get a new engine, crate motors are the way to go. They have good power and I know of a couple that are getting ready to turn 100,000 miles. Plus, you can't beat the warranty. I'd say go for it.
  3. sickquad
    Jul 23, 2003
    785
    Ma
    If anyone has experience with these motors I would love the input. I'm new to the full size chevy world. Convert from the jeep world.
  4. RockyRider13
    RockyRider13 1/2 ton status
    Jul 11, 2001
    102
    Kansas
    I'd go with the newer engine. One piece rear main seal, and set up for roller lifters.
  5. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    the universal 350, the cheap goodwrench one, is about $1200, and produces 260hp, 350 ft. lbs. I have it, I think it's underrated- when I had my 12b with 4.88s and a posi- it would EASLIY turn both over through 2nd on dry pavement.
    It'll still turn one over with my 3.73s and no posi.
  6. crazykev4x4
    crazykev4x4 1/2 ton status
    Jun 30, 2003
    430
    Watertown,Wisconsin
    the LO5 is the tbi engine 210@ 4000rpm is what they put out . im doing an engine swap right now in my 88K5 im installing a vortec 350 froma 96 and up pickup it is a L31 . roller cam and stuff vortec 350 from the factory is 255 horse and with aluminum intake headers and dual exhaust the numbers would probly be around 300 horse or so . im gonna run my TBI on mine
  7. alf4444
    alf4444 1/2 ton status
    Nov 1, 2002
    2,051
    T-ville, ut.
    I agree I just put one in and i think you should be able to build it up to put out more hp than the 330 hp ho for less money.
  8. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,084
    486
    Grand Rapids area
    I have the Goodwrench motor too. I like it. With just headers, dual exhaust some timing work and a new air intake, I am 100hp over stock (original engine was 305)
  9. Blue85
    Jul 26, 2000
    9,084
    486
    Grand Rapids area
    Here's an aticle from CHP where they get about 300hp from it with just headers, intake and cam. Goodwrench Quest
  10. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Get the 383-HT strait from your local GM dealership. You'll be happy with the extra torque of the 383-HT.
  11. loudnowlouder
    loudnowlouder 1/2 ton status
    Jan 29, 2001
    539
    Ellicott City, MD
    i spent the cash on a 330hp 350HO about 2 years ago...the engine itself runs great, HUGE improvement over the 305 running on 6 cyl....
    but i had several problems with seals leaking...first to go was the rear main, then the intake seal went south...
    they only have a parts warranty, so its pretty much useless for things like this, the seals arent that expensive, but i spent a ton of time swapping out seals on a motor that had less than 2000 miles on it...
    other than that i cant say a bad word about the engine, plenty of power, sounds great, turned it into a new truck until the rust took over!
    my only advise would be to stay away from the deluxe version, it came with a holley 4160, which really has no business going off road, your'e better off buying the right carb and a low rise intake, the high rise is great on road, but the power is a little too high for me when off roading...
    good luck!
  12. crroy71
    crroy71 Registered Member
    Jun 23, 2002
    38
    Mont Belvieu TX
    I have to agree.
    HP is good, but torq is king when it comes down to getting these monsters going.
    I am in the process of building a 390hp 457ft/lbs 383 right now.
  13. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    The 87' to 93 motor will probably need a different flex plate for the 1 piece RMS. Why not build a motor? How about a pumped up 406! /forums/images/graemlins/thumb.gif
    85K5 3/4ton,14boltFF,10bolt,9"lift,35"boggers,16.5x14 welds, 406 SBC/700r4 /forums/images/graemlins/k5.gif /forums/images/graemlins/angryfire.gif
  14. sickquad
    Jul 23, 2003
    785
    Ma
    Thanks guys, good info. I'm going to buy a goodwrench motor. With a good intake and headers it will produce all the power I need, for now. We mostly trail ride around here, traction is usually more important than power. Plus traction is cheaper than power.
    Chris
  15. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    '86 and later are already 1 piece RMS.
  16. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    I think you made a good choice. The basic GM 2350 is a good, solid, reliable motor with little or no mods. I started with this motor 2 years ago. For me, it wasn't quite enough. I dumped about $500 or so in it on internals (cam, lifters, springs, rockers, etc) and got it up to around 320 HP. Coming from a 305 motor with 170k miles on it that ORIGINALLY only produced 160HP OEM, it was a huge improvement. I have also since taken the same motor and bumped it up to 420+ HP by converting it to a solid 383. By getting a new GM crate, the block will be thick enough (and not sleeved) that you can do this too in the future if you decide you need more low end grunt.
    Key here is you will be starting with a solid, reliable, bolt-in and go motor. You will have the core of what it takes to build just about anything you want, constrained more by your pocketbook that the engines limitations.
    Have fun!
