engine setbacks?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bablazer73, Jul 20, 2000.
  1. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    has anybody ever played with setting the engine farther back in the chassis? I am getting ready to swap body's on my truck, while the engine is out, I was thinking of setting the engine back about 4". the problem I have is when the truck leaves the ground, I.E. when I jump. it comes down hard nose first. i am putting a bigblock in this year and that will make this problem worse. I know alot of you guys are crawlers and think this is stupid, but i am not a sane person. I like to abuse my truck, but don't like to crash.
    your right. I don't understand the jeep thing!
  2. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    Cut a big hole in the firewall and scoot her back! 4 inches should help allot. Your rear shaft will have to be shortened and front lengthened, could be a problem with a big lift. Maybe you should check into some off-road racing type springs, like National or Deaver if you jump allot like this......
    Michael [​IMG] http://jmartin.net/parker/goose.htm
  3. jcg
    jcg 1/2 ton status
    Mar 19, 2000
    660
    Rochester, NY
    I don't know if you can move the engine much, mine is so tight to the firewall that I had to cut the old sparkplug wires off when I put in my ignition system. It looked like the wires were put on the engine before it was put in the truck. There's less than an inch of clearance between my valve covers and the firewall. Is this the same for everyone else?
    Joe
    Rochester Institute of Technology Team Mini-Baja
    88 Jimmy
  4. bablazer73
    Apr 4, 2000
    3,363
    upstate ny
    I don't have a problem "carving" the fire wall to make it fit. had to do lots of that on my old drag car. 64 pontiac, bb chevy set back 6", tubed out. just want to know If anybody else has done this. I know I am going to have probs with rear shaft. getting a new one built with a cardon joint in it. but have to have truck assembled to take measurments. just more bad ideas that roll through my head.
