engine sputtering at shut off..
Discussion in 'The Garage' started by jakeslim, Nov 17, 2002.
  1. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    When I turn off the engine, it sputters for a few seconds before shutting down. Always when engine is warm. 77 blazer with 383. Is it vacuum leak? bad carb? Any help is appreciated from the experts here.
  2. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    Excess heat will cause the sputtering after engine shut down. Though the sparks are not firing, the A/F mixture is getting ignited by cherry red deposits in the cylinder. /forums/images/graemlins/burb.gif
  3. hammer
    hammer 1/2 ton status
    Aug 29, 2001
    449
    Binghamton N.Y.
    choke out of adjustment
  4. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    some one else around here i think said timing might be to far advanced but im not sure
  5. unsane
    unsane Guest
    That was an option in '77 called AUTOMATIC OVERRUN /forums/images/graemlins/wink.gif
