Engine stalling.. dies, codes?
Discussion in 'The Garage' started by stockk5, Jan 11, 2007.
  1. stockk5
    Apr 13, 2004
    2,035
    71
    Cromwell, CT
    Hey guys, my 87tbi 350 is acting so crazy. Ill be driving down the road and my engine will just cut out for a second, or ill be leaving a light, mostly on turns and the whole truck just dies cept electrical. It's been doing this for a while. Seems to do it worse when the engine gets hot. The check engine light comes on sometimes, but not every time it cuts out and dies.
    For example i drove about 40mins at about 45-50mph, towards the end of the drive, starting off a light my truck started jerking like the engine was running out of gas. I had a full tank. If i completely MASH it, then it stops spuddering. I have new plugs, wires, cap,rotor, ignition module, and fuel filter.
    My main question with all this is, if i plug a code reader into it, w/ no check engine light on, will it give me a code for something being wrong? I tried the paper clip thing, doesnt tell me anything, both w/ light being on and no light on. And what the heck could it be wrong w/ it?
  2. Jason4x4
    Jason4x4 1/2 ton status
    Nov 5, 2006
    4,505
    6
    Chandler, AZ
    just by the description is sounds to me like a TPS going out, the computer might not be seeing the throttle opening, so it can't compensate fuel pulse. it could also be a hundred other things. are you sure the paper clip was on the correct terminals?
  3. stockk5
    Apr 13, 2004
    2,035
    71
    Cromwell, CT
    yeah.. i went over the paper clip thing many times. was in the correct thing. If i try to pull the code w/ no check engine light, will it read anything?
