Engine Stalling When Gunned.......
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 86jimbo, Oct 24, 2005.
  1. 86jimbo
    86jimbo Registered Member
    Sep 8, 2005
    59
    Arkansas
    I have a 86 Jimmy with a 350.
    When Im stopped and just gun it, it stalls out on me, but if I gun it, and it starts to stall, if I let off and gun it again, it will take off. Please help me figure this prob. out. I have a new carb ( holley truck advenger), spark plugs, wires, dist. cap and rotor, control module, and capacitor, and accel coil. I put all these on to resolve the problem, but it didnt. :confused:
  2. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    what kind of fuel pressure?
    whats your timing?
    anyone tune that carb?
  3. 86jimbo
    Sep 8, 2005
    59
    Arkansas
    im running a holley blue electric fuel pump with the regulater set at 6.5 psi, as holley told me. we have messed with the timing, and no results, and holley told me that the carb should be pretty well righ on.
  4. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    I'm not a carb guru, but it sounds like your secondaries are out of adjustment. Are they vacuum or mechanical on that carb?
  5. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    Could be clogged fuel filter. Also there is that little fule pump thingy inside the carb, right? My quadrajet had one, and when it went, it would stall out under more throttle, but run fine at idle or very low throttle. I forget the actual name of the part.. but it's just like a little pump inside the carb.
  6. 86jimbo
    Sep 8, 2005
    59
    Arkansas
    i dont think its the accelerator pump, because my quadrajet was doing the same thing before i changed it out. im thinking it maybe something that i havent checked or replaced. my first guess would be the carb too, but the problem was there with the previous carb (factory)
  7. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    Have you stuck a vacuum guage on the engine? I know some people like the Holley Avenger carbs, but I don't think I've run into a carb that's set correctly at the factory. You need to take into account that each engine is a little different, so each carb needs to be tweaked to fit the engine. I know the Q-jets can really bog if not set correctly and even though I've never dealt with the Avenger, I know most Holley's will bog too if the accelerator pump isn't set right. Someone also mentioned the secondaries, since the secondaries are vacuum operated on your carb you might need a different spring. Just a few thoughts. Good luck! :wink1:
  8. txfiremank5
    Jul 6, 2004
    3,105
    San Antonio, TX.
    Yes, that's the part I was thinking of.. :confused: :D
    Sounds like it may be a tough one to figure out..
