Engine stalls when put in gear.
Discussion in 'The Garage' started by Big GMC truck, Aug 23, 2005.
  1. Big GMC truck
    Big GMC truck Registered Member
    Aug 23, 2005
    73
    California
    I have a 1984 GMC k1500 with a new 305. The truck idles well when it is in park, but will stall when I put it in gear. Any ideas on what is wrong?
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    check for vacuum leaks, carb base gasket, all lines and hoses from intake manifold and carb, including power brake booster one and the one down to the trans modulator valve
    do you know what your idle speed is ? hot ? cold ? out of gear*
    also do you know what your timing is set at ?
  3. Big GMC truck
    Aug 23, 2005
    73
    California
    Could a power brake booster vacuum leak affect the braking quality? The brakes become very hard to press when it does idle in gear for a couple of minutes. I noticed that a little brake fluid was leaking out of the left rear drum. Where is the trans modulator valve? Thanks for your help and time.
  4. 350k5
    350k5 1/2 ton status
    Feb 15, 2005
    115
    Bloomington, IN
    It could also be your transmission... How long has it been on the truck and how long have you been running that new 305 on it? I had a vehicle that did the same thing and it was becasue the transmission was going out. It may not be that serious though but it could be. I would say just check those vacuum lines as was mentioned. That's all I've got.
  5. Roz
    Roz 1/2 ton status
    Mar 27, 2005
    900
    San Diego
    vac leak id say, as long as u havent messed with timing
  6. Roz
    Roz 1/2 ton status
    Mar 27, 2005
    900
    San Diego
    vac leak id say, as long as u havent messed with timing. as to why there is a leak :thinking:
  7. diesel4me
    Jul 24, 2003
    17,561
    942
    Massachussetts
    how does it "die"??
    Does it sputter and stall,or does it stop abruptly ,like a manual tranny if you pop the clutch in gear??--if it stops like that,it could be the lock up torque converter isn't unlocking (assuming you have one--all 700R4's do,and some TH350's)...other than that,it could be vacuum leaks,carb problems,or timing related.. :crazy:
