engine still turnin over after i turn it off.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by k5ntexas, Dec 27, 2001.
  1. k5ntexas
    k5ntexas 1/2 ton status
    Oct 29, 2001
    2,517
    corpus christi, texas.
    well basically what the subject says. i have a re-maned q jet and when it does go for a while after i turn it off it smells really really rich when it does finally die. it only happens when the engine is warm. i have no clue on what it could be so i'm askin ya'll. anything would be helpful. thanx in advance. later.
    jacob
    what is that low rider doing under my k5?
    wow nice lil jap car. whats it good for?
  2. k5ntexas
    Oct 29, 2001
    2,517
    oh i forgot to mention. it just stutters. it don't run like i have it on. it goes like it wants to turn off and it wants to be on at the same time. sorry i didn't mention that before. hope this helps a bit more. thanx again. later.
    jacob
  3. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    The "dieseling" phenomenon. This can happen when running extremely rich, or extremely hot. I forget how to use a carb, though, so I'm going now...
    Ratch
    <a target="_blank" href=http://k5.8m.com>k5.8m.com</a>
    Welcome to America.
  4. mudhog
    Nov 6, 2000
    17,899
    portland oregon
  5. k5ntexas
    Oct 29, 2001
    2,517
    thanx. i'm gonna try that in the mornin. going to the ranch friday so i'm changing oil, checking fluids, and fixin little problems. thanx alot. later.
    jacob
  6. MXmastermike
    MXmastermike 1/2 ton status
    Dec 23, 2001
    167
    Columbus, Ohio
    I don't know a whole lot about engines, but I listen to some cartalk show on NPR and they said that dieseling can be caused by excessive carbon buildup on the pistons, and that there is some crap you can mix in your gas to help take care of it, but I forget the name of the stuff.
    Signature???? What's a signature? I guess I'm gonna find out.
  7. Grim-Reaper
    7,385
    Atlanta
    Let me guess...the box that the reman carb came in said Holly.
    Get you a vac gage. hook it to where the line goes for the aircleaner Thermac control. set the idle to 600 rpm. adjust one side of the carb till you get the highest reading. burp (quick rev) it a few times to clear it out. Do the other side and burp it. do it all a second time to make sure the carb is evened out. give each mix screw a 1/4 turn leand (clock wise) see how it does after that.
    MX is correct about carbon build up. what will happen is a chunk of the carbon is red hot and will cause the engine to deisel.
    Carbon is cause by several things. running rich is one, additives in the gas and in particular stale gas is another, short tripper vehicles (seldon on the hwy only diven a few miles at a time) will often carbon up. never gets hot enough long enough to burn off the carbon.
    Chevy dealer sells some stuff called "Top end engine cleaner" I'll vouch for the stuff., works good. I have seen it free a stuck valve and I ran some through a engine that I was praying was a stuck valve but was burnt. So right after I tried the stuff I had to pull the head. The cabon was all softend up and comming off. Just besure you park the truck nose into the wind. It will smoke like you will not believe when you do this. After running the stuff through it is recomended to replace the plugs.
    Women dig dents and flat paint!
    coloradok5.com/gallery/Grim
    75 Jimmy, Dollar
    Grim-Reaper
  8. Ddragggon
    Ddragggon 1/2 ton status
    Apr 25, 2001
    2,657
    Hartford, WI (formerly Etiwanda, SoCal)
    I may have to check into this top end engine cleaner... mmy K20 is acting pretty craptacular, and with any luck, its nto a burnt valve....
    the other way I've discovered ( when my accelerator stuck in my old truck) is running the engine at 5000 RPM or so for 5-10 seconds will blow out a lot of the carbon... I wouldn't recommend doing this on an older engine, since you could end up breaking something.
    my 454 had a problem with diseling, but I corrected it by removing the Zip tie from the choke on my carbureator ( I live in AZ, and chokes are all but useless) the rotating mass of the bigblock is enough to keep it spinning, and 1/2 fireing long after the engine is shut off. the 454 carb has a small spring that forces the choke shut when the small vacuum device loses vacuum. when you crank the car over, the vacuum device pulls the choke back open, allowing the engine to breath.
    good luck wiht it,
    -Rich
    My truck isn't ugly, you have a skewed sense of beauty
    <font color=blue>2007 Ford XLS++ intrepid Ram Superduty 7000 R-type's suck</font color=blue>
  9. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    I've had that problem. Mine was running too rich and the timing was off. It can also be caused by a vacum leak. But since you're smelling gas, I'd bet you're too rich.
    <font color=blue>What part of my brilliance do you not understand?</font color=blue>
    <a target="_blank" href=http://www.bluefox.tv/~lara>My Wonderful Site</a>
  10. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    I have also had this problem when running th cheap gas in a higher compression motor. 87 Octane... diesel... 92 Octane, no diesel.
    Just another possbility.
    Ken H.
    '86 K5 in parts
    1-ton 44 TSLs
    454 BBC, 350 trans, 205 transfer
    Rust free in Michigan!
  11. fright89
    fright89 1/2 ton status
    Sep 27, 2001
    279
    boston
    i had a car that did that. i seem to remember shutting it off in gear. this did not fix the problem but it did not run on so bad.
    not shure why.
  12. 1975k5
    1975k5 Registered Member
    Feb 28, 2001
    44
    Alabama
    These posts are full of " I had the same problem, and this is what.....". My 75 started dieseling this summer when the weather turned warm. I adjusted the idle as low as I could and still idle when in drive. No dieseling. I had tried a new thermostat, plugs, wires, timing, etc... No luck. Idle speed worked.
    Tom
  13. muddin4fun
    Feb 19, 2001
    5,644
    N Texas
    <blockquote><font class="small">In reply to:</font><hr>
    <hr></blockquote>
    Prolly marvel mystery oil. Stuff rocks!
    <font color=blue>Answers: $1, Short: $5, Correct: $25, dumb looks are still free.</font color=blue>
  14. dyeager535
    26,982
    191
    just another thing to check, if so equipped. The solenoid mounted on the carb on the drivers side, that engages the throttle linkage. My '83 would run on when I turned it off, something was wrong with that solenoid, and kept the throttle open when I turned the vehicle off, so it kept running. Pulled the wire off of it and never had a problem again. Pretty sure that solenoid has to do with kicking the idle up when the AC is on. Easy enough to unplug and test though! : )
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
    Why insist on counting when the ring gear has the tooth counts stamped in?
  15. 80K5
    80K5 1/2 ton status
    Jun 5, 2001
    100
    Try turning the idle down. I did that with mine and it fixed it but I also had to rebuild the carb but the idle is an easy one to check out first.
    Stuck? Yep, I'm always stuck!
    Steve!
  16. sinchphoto
    sinchphoto 1/2 ton status
    Mar 7, 2000
    366
    Southern California
    my carb was doing the same thing. so i turned it down 1/4 turn and that did it.
