Engine stoped running
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by pomai, Jun 30, 2005.
  1. pomai
    pomai 1/2 ton status Premium Member
    Jan 26, 2002
    435
    3
    Oahu, Hawaii
    my 88 full size blazer just stoped running while driving on the freeway. It turns over but wont start. the rotor points at the number 1 on the distibutor cap and the timing marks line up on the damper. Any ideas?
    Thanks Ed
  2. J.R.
    J.R. Guest
    well i would start with spark and fuel.. if you have spark then check fuel supply. i have had that happen twice, first was fuel pump. other was ignition.
  3. dyeager535
    26,975
  4. pomai
    Jan 26, 2002
    435
    3
    Oahu, Hawaii
    Thanks, It turnned out to be the ignition moudule. Replaced it with a new one and started right up. Thanks again. Ed
