Engine Stumbles
Discussion in 'The Garage' started by k5freak44, Mar 18, 2006.
  1. k5freak44
    k5freak44 1/2 ton status
    Jun 1, 2004
    2,164
    Plano, TX
    Im starting to get frusturated with my K5 because it isint running the way it should.
    Its a 91 with a 350 and TBI, and when its cold it stumbles and tires to die until its somewhat warm. When i go to give it some gas and its in drive it jerks like its dyeing and then slowly accelerates. If i put the pedal to the floor in drive it makes alot of noise and accelerates to 40mph in about 15 seconds. Another thing that it does mostly when its cold but sometimes when its warm, is when i put it in gear thengine stumbles, most of the time dies unless i give it some gas.
    What is yalls take on this?
    I rebuilt the Throttle body and cleaned the injectors, helped but didnt do much, and i replaced the idle regulation sensor or whatever it is called that screws into the back of the throttle body.
    Jonathan
  2. AZ79K5Project
    AZ79K5Project 1/2 ton status
    Jan 15, 2006
    2,082
    Arizona
    Have you checked the timing? Vacuume leak?
  3. k5freak44
    Jun 1, 2004
    2,164
    Plano, TX
    when the engine is warm it idles just fine tho and only bogs down when i try to accelerate.
    would the timing do that?
    i checked for vaccum leaks and couldent find any
    anone else?
  4. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    Is it tossing out any fault codes? I usually forget to mention that (since mine's a non-OBD-type dinosaur).
  5. AZ79K5Project
    Jan 15, 2006
    2,082
    Arizona
    Timing can cause poor/hesitation on accleration.
