Engine suggestion?
Discussion in 'The Garage' started by BLKWOLF, Dec 30, 2002.
  1. BLKWOLF
    BLKWOLF Registered Member
    Aug 18, 2002
    10
    Colorado
    What would you recommend for an engine upgrade for a full size '89 GMC Jimmy. I'm looking for a fuel injected engine with a balance of speed, power and gas milage. The truck will be my daily driver. Basically, I want an engine that can pass just about anyone on the highway yet not empty the gas tank. Is there a Crate engine you would recommend and with what options? My current TBI 350 c.i. engine gets 12 to 14 mpg. on 35" tires and stock gears.
    Thanks,
    Ray
  2. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    12 to 14 MPG sounds low for a tbi 350. My father-in-laws tbi 454 gets that in a burb. Id say give your moto a good tune up and see if ya cant get those mpg #'s up.
  3. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    GM has a 383-HT crate motor. You could futher upgrade it with a TPI electronic fuel injection system. I really want one of those 383-HT crate motors myself.
  4. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    A gear change might help. Lower gears might get the rpm's back into the power band and actually get you better mileage. More passing power also. Do you know what gears you have now?
  5. BLKWOLF
    Aug 18, 2002
    10
    Colorado
    The gears are stock, which I think are something like 3:96. A friend of mine suggested upgrading my gears to 4:10 or 4:56. I might be getting better gas milage than 12 to 14, but that's just a guess based on the fact my speedometer hasn't been calibrated for my 35" tires, yet.
    Thanks,
    Ray
  6. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Stock gears in an 89 would be either 3.42 or 3.73. Chev didn't have 3.96 gears. With 35's 4.10's or 4.56's would be better...
    Rene
  7. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    with a 700R tranny i would go 4.56 to utilize OD.
  8. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
  9. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    406 TPI like BlazzinOR had. I think he sold it but then again he might not have. Cant remember right now. /forums/images/graemlins/confused.gif
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    400=almost impossible to find
  11. fr8train
    Aug 2, 2000
    1,712
    Maryland
    I can get you one. The yards here are sorta stocked with 400s and 425s.
  12. BLKWOLF
    Aug 18, 2002
    10
    Colorado
    Someone once suggested I look for a multiport fuel injected motor, but I see most people suggesting TBI. They told me that TBI won't perform as well with upgrades such as cams, headers, micro-chips and new ehaust. Can anyone explain the difference between the 2? I'm pretty clueless when it comes to this stuff ;^) What's your opinion on the Ramjet engines or the LS1 crate engines?
    Thanks,
    Ray
  13. BLKWOLF
    Aug 18, 2002
    10
    Colorado
    Thanks Renee, I think those gears are 3:73 ;^)
  14. Mreetz
    Mreetz 1/2 ton status
    Jun 26, 2001
    1,282
    Subs of Denver, Colorado
    I've got a 400 block and new crankshaft for sale! Let me know if you decide to go that way. Marty---
  15. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    I may be interested in the 400 and crankshaft, but I don't want to be a thread pirate. After he makes up his mind let me know......
    John
  16. Mreetz
    Jun 26, 2001
    1,282
    Will do! Its posted way back in the for sale column too.
  17. roostr3269
    roostr3269 1/2 ton status
    Jul 2, 2001
    305
    michigan
    I run a 502 Ram Jet in my '72 Jimmy. I get about 10 mpg, which aint all bad considering the numbers shes puttin out. If you want stump pullin power, go with the 350 rj, or go balls to the wall with a 502, hehe.
  18. BLKWOLF
    Aug 18, 2002
    10
    Colorado
    John, go for it, if you want that engine. I'm not quite in the market yet, for a new engine, but wanted to know what everyone's opinion was here when I am ready.
    roostr3269, how is the R.J. 350's highway passing power? Could I expect about 14 to 16 mpg. with it? This truck is going to be mainly a pavement pounder occasionally going 4 wheeling. I want to turn it into a show truck.
    Thanks,
    Ray
  19. Mreetz
    Jun 26, 2001
    1,282
    Give me a call John, I'm sure we can work something out. I've got a '73 Camaro project goin here too! /forums/images/graemlins/k5.gif
  20. Thunder
    Jul 20, 2000
    8,946
    Northeast Nevada
    TBI perfpoms great with upgrades. I have Edelbrock headers, exhaust, chip, fastchip.com improved K&N intake ect and I am generating plenty of power from a TBI. My blazer will go faster than I want it to. and I get 18 mpg at 70 mph going down the highway
    The main problem with stock TBI is air flow. The link to Turbocity in my other post will cure that. Talk to them they can fix you up with a very good system.
    You can get a chip burned for just about any cam you want too. But the stock chip will work with cams with up to 212 degrees duration and .480" or so of lift. You can pull a lot of torque out of a cam like that.
    Also an adjustable fuel pressure regulator is a must. So you can boost the pressure and fine tune the spray pattern.
    With your truck TBI is probabally the easiest and cheapest way to go.
    If you want to spend more money then go with MPFI
    Here's the link to Howell:howell-efi.com
    Edelbrock and Holley also sell MPFI kits.
    Check them out and you can compair the different systems and decide whats right for you.
    Personally I perfer TBI for a truck. Its rugged dependable and you can get parts fot the GM units anywhere.
