engine swap 305 out 350 in
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mike87k5, Aug 27, 2001.
  1. mike87k5
    mike87k5 Newbie
    Aug 27, 2001
    4
    Florence, SC
    i have an 87 w/305 TBI swapping in a 350 w/ carb. will the TBI bolt up to the same intake as the carb. Or will i have swap intake manifolds and will the swap? And will the same TBI work on the 350 ?
  2. MOABDADC22
    MOABDADC22 1/2 ton status
    Jul 24, 2001
    1,348
    Cheyenne, Wy
    If I am not mistaken.....GM changed cylinder heads in 87. What year 350 are you putting in? The TBI will NOT bolt up directly to a carb manifold. Why not keep the TBI and put in the 350? It is a direct bolt in swap. I don't know for sure but I think you can use the 87 305 ECM for the new 350 TBI.
    <a target="_blank" href=http://www.moabdadc22.alloffroad.com/>http://www.moabdadc22.alloffroad.com/</a>Real four wheelers don't need tools to remove body panels, paint, tail lights..etc.
