Engine Swap and Build Thread
Discussion in 'The Garage' started by noahrob, Jan 19, 2007.
  1. noahrob
    noahrob 1/2 ton status Author
    Nov 26, 2005
    1,878
    Santa Barbara
    So over the course of the last few trips, I began to notice a lose of power. Also, I was getting frustrated as heck with the carb, granted it was better with a couple of fixes from the CK5 Tech section, and the lockright in the front helped tons, but at the end of the day, I knew I wanted some type of Fuel Injection.
    My buddy turned me onto a thread here in CK5 and after a detour on my honeymoon (yes, I said a detour on my honeymoon) I had my new to me engine, a 1986 5.7L TPI. Now the fun...
    Here is the thread I started in the injeciton section to get me going, where I asked incredibly stupid question, and really cool guys like 4X4High, Shoutherspeed, SierraClassic answered a lot of questions, thank you guys...
    http://coloradok5.com/forums/showthread.php?t=193978
    OK, here we go:
    1) Out comes the 383
    2) In goes the ORD cross memeber (this was a PITA) and DIY4X engine mounts
    3) In goes the new engine
    4) Fancy home made bracket since the engine had a hydroboost power steering pump and when I put mine on the brakets were all different.
    5) Electric Fuel pump
  2. noahrob
    Nov 26, 2005
    1,878
    Santa Barbara
    1) The fuel return line is going to dump into the filler neck, so I had to get a bung (my new favorite word of the week) and a 1" hole saw.
    2) I decided to use my long tube Doug Thorley's which means the O2 sensor have to get on there...another bung!
    3) Here is the 3/8 inlet to the filler neck (no comments on that weld please:crazy: )
    4) Headers on...
  3. muddermilitia
    muddermilitia ThatTrazerGuy GMOTM Winner
    Nov 10, 2005
    5,742
    76
    NE Illinois
    Looking good, keep up the good work :thumb:
  4. noahrob
    Nov 26, 2005
    1,878
    Santa Barbara
    Update...things were going great until I had a major accident...luckily, duct tape can fix anything...:D
  5. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Did you hurt yourself or did you have a slipper blowout?:D
    Ira
  6. noahrob
    Nov 26, 2005
    1,878
    Santa Barbara
    Slipper blowout...if I put a picture everytime I hurt myself workin on my truck, CK5 would be a porn site of my body parts...I am sure I am like most of us, when I say I put "blood, sweat, and tears" into my truck, I am not joking. But man, when it finally works....ahhhh:D and when it doesn't..well:mad:
  7. noahrob
    Nov 26, 2005
    1,878
    Santa Barbara
    I tracked down and labeled all the engine side wires BEFORE I fed the harness thru the firewall...good news is that I know what all (most) the wires are for, the bad news is I drilled the hole in the firewall in the wrong place...dooh.
  8. chromewontgetyouhome
    chromewontgetyouhome Registered Member
    Aug 1, 2004
    69
    Big Island, Hawaii
    What problems did you run into with the ORD crossmember?
  9. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    What kind of fuel pump is that? It will supply the needed pressure to the TPI setup?
  10. noahrob
    Nov 26, 2005
    1,878
    Santa Barbara
    working in the rain sucks...but I made a lot of progress...Got the harness on, the computer mounted and the clip back on...
    The fuel pump is an airtek, I got the part number from Ryan B.'a TPI thread in teh tech section..rated at 125 psi
  11. noahrob
    Nov 26, 2005
    1,878
    Santa Barbara
    Also, the only issue I has with the ORD cross member was drilling holes...not really an issue, more just a PITA to get the drill wedged between the springs and the frame...
  12. noahrob
    Nov 26, 2005
    1,878
    Santa Barbara
    Well, I probably would have gotten it running today except I decided to redo teh fuel line...I was going hose and decided to just do the stupid hard line...Also, I need a new throttle cable (any thoughts). I tried using one from a camaro, but no workie...which means I have a brand new throttle cable for sale...
    Also, when I truned the key one, I clearly heard the fuel pump come on, good right? Should fuel come out right away or not until the engine turns over...?
  13. dyeager535
    26,982
    191
    Ugh. I wish I knew the throttle cable I've got. What year did you end up with?
    Mines a Camaro app, had to modify the firewall just a tad to make the "clip" work there, and the length was plenty (actually a complete extra loop lol) but it works fine.
    Whats the end on the cable? Barrel or other? Mines a barrel end that slips into the TB linkage. I think I may still have the email where I went over this with the guy I got the stuff from. IIRC there are only two styles, the '85-89 and 90-92, but the year break may be different. I've got an '87 TB. Maybe a pic of your throttle body where the linkage goes if its not the "groove/barrel" setup like I'm trying to (poorly) describe.
    Yes, fuel pump will run with KOEO, but no spray until it cranks. Should shut off after a couple of seconds at most of run time with no cranking.
  14. noahrob
    Nov 26, 2005
    1,878
    Santa Barbara
    Cool, then I am almost there...
    the camaro calbe I have has a barrel end on it, like what you woudl use for th ebrake lever of a bicycle...but the linkage on the TPI needs a cable with a hole in it like the carb...how did you loop it, maybe I'll try that?
  15. buefchris
    buefchris 1/2 ton status GMOTM Winner
    Dec 28, 2005
    1,503
    buena park ca.
    I put a TPI out of a 90 corvette in my 85 pickup, they can try your Patience with all the codes and limited selection of camshafts that the computer will accept. I hope you have a easier time than I did.
  16. noahrob
    Nov 26, 2005
    1,878
    Santa Barbara
    Since this a a complete engine, with harness and computer out of a running truck, I am hopeful it will work well out of the gate. Might be abel to start it today, need to figure out how to hook up the tach...but then...vrmmm...
