engine swap question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by roostr3269, Jan 28, 2003.
  1. roostr3269
    roostr3269 1/2 ton status
    Jul 2, 2001
    305
    michigan
    I have a friend that has a 1989 chevy half ton p/u w/ tbi 350/5 speed. He wants to put in an older(built 1970's carb. 350). Will this go right in, tranny issues? thanx in advance.
  2. Sidepipes
    Sidepipes 1/2 ton status
    Nov 9, 2002
    139
    St. Thomas, Ontario, Canada
    86/87( can't remember) and up 350's have an externally balanced flywheel/flexplate, the 70's require a neutral balance flywheel. It shouldn't be to expensive to get one from a parts house. Just get the right size!
  3. roostr3269
    Jul 2, 2001
    305
    michigan
    Thanx Mike, I appreciate it.
  4. fenderbender
    fenderbender Registered Member
    Feb 1, 2003
    37
    NE GA USA
    All 350 are balanced the same
  5. 95 Silverado
    95 Silverado 1/2 ton status
    Nov 9, 2001
    467
    Central PA
    The engine flywheels are different, the later engine has a one piece rear seal crankshaft, the earlier engines have a two piece rear seal, the ends of the crankshafts are different due to the different seal designs requiring a flywheel to match the crankshaft.
