Engine Swap... WONT START
Discussion in 'The Garage' started by BlackDog714, Dec 1, 2004.
  1. BlackDog714
    BlackDog714 1/2 ton status
    Jun 8, 2002
    260
    Indiana
    Ok, its a 92 K code 350 with a Painless harness (60101) in my 85 K5. It turns over, I have fuel and spark, but it wont light off... I can get it to fire for a few seconds while the started is cranking, but then nothing.
    I think the timing is off, but I am not getting ANY backfiring (well once, but there was gas dripping out of the header). I set it up to TDC and ran the plugs like that, I set it up 180 out to see if that was it, but nothing is working.
    It was running before I put it in my truck, but I messed up the timing and didn't mark #1 like an idiot /forums/images/graemlins/yikes.gif
    HELP /forums/images/graemlins/1zhelp.gif
  2. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Doo you have the firing order correct?
    Twist the dist. while soomeone is turning the key. Stay awaay from the intake and the fan....
  3. dyeager535
    26,982
    191
    Do you have a timing light?
    Set the engine to TDC, as you know.
    Hook the timing light up like normal. If its adjustable, make sure it's on 0.
    Turn key to run. Hold trigger on gun down, turn distributor until it fires. On my TPI I have to essentially "jerk" the distributor quickly so that it fires, but you can just narrow it down by doing it in smaller increments back and forth.
    It will fire every time it hits the rigth spot, so you can lock it down there. In any case, this will get you close enough that if it's working right, it WILL run. You should hear the fuel pump fire each time as well.
    The timing disconnect shouldn't matter in this case, but it will once it starts running, so I'd disconnect it as well.
