engine swap
Discussion in 'The Garage' started by August, Feb 20, 2006.
  1. August
    August Registered Member
    Nov 27, 2005
    20
    Spain
    Hello,
    I have a 1979 Chevrolet Silverado with a broken 350 engine (overheat, broken pistons, bended conecting rods). I also have a good running but ugly 1980 Pontiac Lemans with a 305 2bbl... I was told that the 305 is a chevrolet engine. Can I put this engine in the Silverado? I don´t know if the Pontiac has a th-250 or a th-350, but will the 305 match the th-350 silverado transmission? Is a straight forward swapping or it needs hammer and welding?
    Thanks for your help,
    August
  2. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    it will drop right in, a direct bolt in. that being said, dont waste your time, find a cheap 350 either from a junkyard or classifieds and throw that in, 305s are very slow in stock form
  3. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    I agree with the idea of getting a 350. I have a 305 in my 86 k5 now and a fresh 350 waiting to go in...unfortunatly with almost 130k miles the 305 doesn't even tap. At worst it diesels a bit but that could be hot plugs. 305 may be a bit weak but the bastards are durable. I can't kill this motor and I been tryin.
  4. August
    Nov 27, 2005
    20
    Spain
    Thanks for your replies. Well, I forgot to say that I am not in the US, I am in Spain, so I have not a big offer in engines...
    I may have a 350 bit it is from 85 and it is bolted to a 700 r4, is it a problem?
    Thanks again,
    August
  5. 76zimmer
    76zimmer Flyin Rat Premium Member GMOTM Winner
    Nov 14, 2005
    23,034
    1,349
    Kzoo, Mi
    The exhaust manifolds, and oil pan dipstick are probably different. Check the bolt holes in the heads, to see if you have a combo that will bolt up, the dipstick is probably on the pass side of the 85 engine.
