engine swap
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by txbluethunder, Apr 5, 2002.
  1. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    ok...i'm looking at doing a 1985 350 swap in place of my 1986 305 in the next coming weeks. i'm buying the oem replacement engine from scoggin dickey http://www.sdpc2000.com/cart.asp?action=prod_detail&catid=130&pid=383 for this and im wondering, other than the new flex plate http://www.sdpc2000.com/cart.asp?action=prod_detail&catid=882&pid=1196 what else will i need to make this swap.
    i already plan on a new water pump, fuel pump, vacuum hoses, belts & dampener. any help would be great as this is only my second time to replace an engine and my first at swapping different engines.
    ...russell
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    As far as I remember you don't NEED anything beside the flexplate. If I were you I would replace the computer controlled carb and distributor.
  3. rlhenry
    rlhenry Registered Member
    Mar 6, 2002
    93
    Morenci, AZ
    I did a similar swap in my '84. I was told by a guy at a tranny shop that I needed to replace the torque converter as well. I knew the tranny was due for a rebuild, so I held off for a few months and changed the converter when I did the tranny rebuild. Anyone else ever heard that?
  4. txbluethunder
    Jan 29, 2002
    835
    Austin, TX
    yea..i would love to replace them but my money tree died /forums/images/icons/smile.gif
    maybe soon...
  5. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Understood. If I were you, or if I were me with the chance to do it over I would have put an MSD billet distributor in my truck, and next time the damn carb needs rebuilt I am getting a Jet stage 2. Also if you can nurse the money tree for a little cash I would try and get myself an MSD box for the new 350. It really helps the motor out. It really helped my 300hp crate from GM, and would have helped the stock replacement crate I had alot too.
