Engine swap
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blades17, Nov 29, 2000.
  1. blades17
    blades17 Newbie
    Nov 29, 2000
    WI
    Hello everyone I am new to the forums and am looking forward to loads of awesome information. I have a question about swaping a vortec 350 out of a 99 yukon into a 89 jimmy. I have located the new motor and it comes with the computer and all wiring harness. The current Transmission in the jimmy is a 700-r4. Is this a possible swap and if so what sort of modifications would be necessary. Any thoughts would be greatly appreciated. Thank you.
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    Not sure, but you may have to use and external type controller for the lock up converter on the 700r4. I doubt the 99 Yukon comp will control it.
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; http://emmett.coloradok5.com
  3. backlash
    backlash 1/2 ton status
    Oct 21, 2000
    519
    Northern, VA.
    Did you get it off EBay? Was looking at that for my 88. Be interested to see how the swap goes. Don't think too many have done that here. Blazer in Oregan just finished a swap, not sure of his tranny though. Maybe you could contact tech support at Chevrolet for questions concerning the match up.
    Bet someone will be along soon to answer.
    Good luck.
  4. shum1
    shum1 1/2 ton status
    Oct 8, 2000
    270
    UTAH
    I asked the same question a while back, do a search under "vortec" and see the responses. There is some good feedback but I'm still not clear about what it involves. Is that the 350 vortec or the 5.3?
  5. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    I'm still running my T350 behind the TPI 406, but have plans to do the 700R4. My computer has the 700R4 hookup wires so I am set. Didn't the new Yukons come with the 4L60 (same thing as a 700R4)? Seems it would be much the same, tho I know jack about this tranny compatibility.
    <font color=black>'79 - 406 TPI -<font color=orange> K5#5 - <font color=blue>See it at---&gt;http://www.blazzinor.coloradok5.com
  6. EDdaTREE
    EDdaTREE 1/2 ton status
    Feb 18, 2000
    1,253
    Austintown, OHIO
    Go to www.paceparts.com if ya run into trouble and their tech.-helpline guys should be able to fix you up.
    "I'm not stuck...I'm just resting!"
  7. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    BlazzinOR, the '99 Yukon came with the 4L60E. Note the "E" on the end, as in "Electronic". The shifting on that tranny is computer controlled. So it won't work with the 700R4 wiring that you have in your current harness.
    The only info sent between the 700R4 and the ECM is the 700R4 tells the ECM when it's in 4th gear and the ECM tells the 700R4 when it's OK to lock up the torque converter (there's still a hydraulic override within the 700R4 that won't lock the converter until the tranny thinks it's OK to do so).
    http://ThunderTruck.ColoradoK5.com
