Engine swapped, now no SPARK!
Discussion in 'The Garage' started by bigoltrux77, Nov 5, 2006.
  1. bigoltrux77
    bigoltrux77 1/2 ton status
    Jun 12, 2002
    318
    Fort Polk, LA
    I got everything on my engine and started cranking her over and i have no spark. So i tested the red wire that goes into the battery terminal of the Cap and its only getting 3 volts or so when the key is in the on posistion. My question is, where does that red/pink wire lead to? I was thinking of clipping the connector off and running new wire but i dont know what it runs too. It leads somewhere into the firewall i believe. Anyone know?
  2. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    that should be a switched hot wire, running off the ignition switch i would imagine...
  3. BadBob
    BadBob 1/2 ton status
    Aug 14, 2005
    158
    Lyndon, KS
    If everthing was ok before the engine swap, you might check to make sure you hooked your ground straps back up (engine to firewall and frame). I've done that a couple times.
  4. bigoltrux77
    Jun 12, 2002
    318
    Fort Polk, LA
    How many grounds should i have? There is so much extra wiring from the A/C i dont know whats what. So if run a wire to an ignition source it will be right? Right now i have two grounds besides the Battery, grounded to the Block. Am i missing one?
  5. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    there should be one ground from motor to body, body to frame, battery to motor
  6. bigoltrux77
    Jun 12, 2002
    318
    Fort Polk, LA
