Engine temp high
Discussion in 'The Garage' started by BLZN4FN, Mar 10, 2007.
  1. BLZN4FN
    BLZN4FN 1/2 ton status
    Dec 19, 2000
    1,720
    Englewood Colorado
    Well I drove the K5 to work and the coolant temp is at the 210 mark. It never runs this high.
    I'm going to start with fresh coolant and a new t-stat. Which temp should I use 175,185,195??
    Also which is the best way to check to see if my clutch fan is working properly?
  2. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    195 especially in your climate
  3. Jimbo*
    Jimbo* 1/2 ton status
    Mar 8, 2005
    1,420
    roswell, new mexico
    On the fan clutch, first see if you can wobble the fan . If you can move it even a little bit, it's probably time for replacement. Also check for oil/dirt around the hub; front or rear. If there is oily/dirty residue,chances are the seal has gone and the clutch is toast.
    Jimbo
