Engine temp??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by txbartman, Jan 4, 2002.
  1. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    What's the normal operating temp of my 305? And, when swapping in the 350, should I use the same thermostat? Or should I replace it with a new one of the same temp or a new one of a different temp?
    Recommendations?
    Brian
    Check out <a target="_blank" href=http://tx85gmcguy.alloffroad.com>My Jimmy</a> with all her projects!
  2. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    It should have been 180 from the factory. The TBI trucks came with 195 t-stats. I personally like running a 160 in my '85 with a mild 350. I am in Alabama and don't really need the extra heat. Hope this helps.
    '85 K5 : Run it til it breaks, then fix it and go again!
  3. JIM88K5
    JIM88K5 1/2 ton status
    Apr 27, 2001
    1,384
    Vancouver, Wa
    Put in a brand new AC Delco 195 degree (factory stock).
    -Jim
    88 Silverado K5 5.7-700R-208-10 bolts-4.56-35in
    Procomp AT's- some ORD stuff & a CV driveshaft
  4. K5Jimmy
    K5Jimmy 1/2 ton status
    Sep 21, 2000
    1,141
    Lake Dardanelle/Logan Co, Ark
    I run a 180 in my 89.....I can idle in August with the AC on.....no prob.....
    Stuck?...Hell no..I still got some gas left..
