Engine Theory Question
Discussion in 'The Lounge' started by ARAMP1, Feb 6, 2007.
  1. ARAMP1
    ARAMP1 Aviator Extraordinaire
    Sep 1, 2005
    3,983
    55
    Memphis, TN
    There is/was an equation where you could determine the ideal V angle of an engine, but I've forgotten it and can't seem to find it. Any help?
  2. ARAMP1
    Sep 1, 2005
    3,983
    55
    Memphis, TN
    I think it assumed that opposite banks of cylinders shared the same crank pin.
  3. dogdaysunrise
    dogdaysunrise 1/2 ton status
    Jan 19, 2005
    2,719
    Winterpeg
    you might have better luck with this one in the Garage.
  4. ARAMP1
    Sep 1, 2005
    3,983
    55
    Memphis, TN
    I think I've kind of figured it out. I believe the angle between the V needs to be a multiple of 720/#of cylinders. (unless you have something like an odd fire V6 which instead of 60/120 degrees between the V you have 90 and it fires at 90 between each bank and 150 degrees between the three 90s.)
  5. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    So if a fat chick falls in the forest? Do the tree's hear it?
  6. dogdaysunrise
    Jan 19, 2005
    2,719
    Winterpeg
    They uproot from the quake.
  7. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    The only engine that I know of that shares the same crank pin/journal is the Harley Davidson V-Twin. It is that configuration that gives it that distinctive "Harley" sound........
  8. ARAMP1
    Sep 1, 2005
    3,983
    55
    Memphis, TN
    Pretty much every domestic 90 degree V8 that I can think of has opposite cylinders sharing crank pins. IE; in a small block chevy, there are 5 main journals and 4 connecting rod journals.
  9. Corey 78K5
    13,055
    Humboldt County, CA
    I guess I was thinking of V-twin motorcycle engines:doah: Hell I don't know it was on some show I watched once. Fock it it's late I'm going to bed.......
  10. ARAMP1
    Sep 1, 2005
    3,983
    55
    Memphis, TN
    It's all good, bro. :D
  11. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    I don't know the equation, but here's some food for thought;
    At one time Cadillac made either a V12 or V16 with 135 degree cylinder angles. I wonder what THAT crankshaft looked like????
  12. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    are you thinking of what the best angle for a given number of cylinders in a v configuration, as to why the 60 degree V6 is 60 degrees?
  13. kgillyk5
    kgillyk5 1/2 ton status
    May 29, 2003
    1,830
    Fultonville, NY USA
    How did I get in the Garage??? Wait...WTF???,...where am I?
    PAD...:p:
