engine / tranny noise
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by caryhenry, Oct 12, 2002.
  1. caryhenry
    caryhenry Registered Member
    Sep 28, 2002
    78
    Tallahassee, Fl
    I have an 85 with the 305 and the 700R4 tranny. I can hear an intermittent rattling/grinding noise, and when I go under the truck it sounds like its coming from the flywheel/torque converter area. It is hard to hear in park, but in reverse it's pretty noticeable. Any suggestions?
  2. dyeager535
    26,979
    Check the flexplate to converter bolts, flexplate to crank bolts, and finally, the entire flexplate itself. Usually under heavy load (like starting up an incline from a stop) you will hear a cracked flexplate.
