Engine Transplant S.O.S.!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by sexysilverado, May 17, 2000.
  1. sexysilverado
    sexysilverado Newbie
    May 17, 2000
    3
    Help!!! Found healthy, strong EFI 350(from '87 K5 Silverado) to replace the recently expired carbed 305 in my '86 Silvy. But now, after weeks of slow motion "green light" updates from my slow-but-steady mechanic, he informs me just today that the air intakes are the wrong size/type and my "new" engine can't be used. All my instincts and most of my homework suggest he's dead wrong. Anyone out there shed some light on this for me?
    Sexysilverado
  2. chaka73
    chaka73 1/2 ton status
    377
    Southern California
    To me that sounds about right, you should be able to use it, unless somebody else knows why it wouldn't fit please tell us.
    LOVE MY GREEN GIANT!!!
  3. Truckfan2
    Truckfan2 1/2 ton status
    Apr 10, 2000
    343
    Northern IL
    Well, if you got an engine that was complete than you shouldn't need to switch the air intakes?!?(intake manifold?) The '87 is a TBI and the only diff between the '87 and '86 are the intake manifolds for the diff. applications (carb and TBI). The bolt patterns are the same on both intakes so they're interchangable. Hope that helped... if you got any more Q's e-mail me. Oh yeah... who is your mechanic and does he know anything about the SBC??
    NEVER been stuck... *yet*
  4. sexysilverado
    May 17, 2000
    3
    Help a girl out here. Know most of the abbreviations, but what's SBC?
    Sexysilverado
  5. scavenger
    scavenger 1/2 ton status
    Mar 31, 2000
    111
    Southern Wisconsin
    SBC stands for SMALL BLOCK CHEVY engine
  6. sexysilverado
    May 17, 2000
    3
    Thanks.
    Sexysilverado
  7. Truckfan2
    Apr 10, 2000
    343
    Northern IL
    it'd help if you filled out your profile... where are you located?
  8. Nrose07
    Nrose07 1/2 ton status
    Mar 29, 2000
    267
    Salem ,Or
    Wow another woman??? Where are you located! Ok,ok just kinda exciting. Well just one question, what are "air intakes"? Intake ports? Air tubes to the carb/tbi? What do you mean by this. As previously posted the 87'to 95' intake manifolds will bolt on to 86' and prior engines (and vise versa). But the two center bolts on the both sides of the intake will need to be drilled out to alow the bolt to line up (they changed the angle). But wait! As I read you post again, and are you just using the engine from the 87' or everything (the fuel injection also)? Any which way you can overcome any small problems between the 2 years of engines, the difference are small. Hope it helps! Matt
    Displacement, cubes, and did you say you drive a riceburner???
  9. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    the center bolts are at different angles. the newer bolts are more upanddown than the older ones. b@m had a kit to correct this problem with wedges to give you a bolting surface.
    your right. I don't understand the jeep thing!
  10. Eagle86K5
    Eagle86K5 1/2 ton status
    Mar 5, 2000
    974
    Whitehouse, Ohio
    I wonder if she got all the stuff to go with the new engine, wiring harness, sensors, computer etc, if not he might be saying the efi will not work and he needs to put carb intake on the new one for it too work.... I have not played with anything past regular carburation....so you guys explain it to the little Lady...
    <font color=green>[​IMG]Eagle86K5[​IMG]<font color=red>
    Masonry...It's a Good Thing
    2B1ASK1
  11. Shawn
    Shawn 1/2 ton status Premium Member Author
    1,753
    5
    5280'
    If you are planning to put a carb back on and don't want to mess with drilling the old manifold, Edelbrock makes an intake that fits the 87 engine and a standard carb. I did this on my old 87 350 with a Edelbrock carb.
    Performer #2104 (non egr)
    Performer #3706 (egr)
    This came from Edelbrocks site:
    Designed for street 262-400 c.i.d. Chevy V8s with 1987-95 cast iron heads with canted center bolt holes. #2104 is stock replacement/street legal part for 302, 327, 350 V8s with 1987-95 heads with OEM 4-bbl. carb.; except stock equipped EGR. #3706 is stock replacement/street legal part for 305, 350 V8s with OEM 4-bbl. carb.; 1987-95. Both accept late-model waterneck, air-conditioning, alternator, H.E.I. and have rear water crossovers.
    Shawn
    87 K5
  12. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    More tips on initials:
    EGR = Exhaust gas recirculation, meaning that a part meets regulations for pollution controls.
    CID = Cubic Inches of Displacement
    4 Bbl carb = a carburetor with four barrels for air intake.
    HEI = High Energy Ignition (not so sure about this one).
    <font color=black>//////
    What the heck!...Drive it like gas is $0.50/gal!!!
    </font color=black>[​IMG]
