Engine trouble
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MA87K5, Jun 29, 2000.
  1. MA87K5
    MA87K5 1/2 ton status
    Apr 6, 2000
    558
    Chicopee, Ma 01020
    The problem that I have is my engine bucks when I give it just enough gas to move. And it will try to stall when I drive slow for about 30 feet and then turn. Distance varies though. It also barely bucks at around cruising speed. Can someone please help? The air cleaner in new, and fuel pump, and fuel filter.
  2. White Knight
    White Knight 1/2 ton status
    889
    Ft Worth,Texas
    Auto or standard?
  3. MudRebel350
    MudRebel350 1/2 ton status
    May 20, 2000
    324
    N.J.
    Did you make sure you put the fuel filter on the right way? The arrows should face towards the front of the truck. Has it turned on the service engine soon lite?
    J.D.
    88 Gmc Jimmy
  4. 4x4blazer
    4x4blazer 1/2 ton status
    Jun 14, 2000
    278
    Louisiana
    Check the timing maybe ?
  5. MA87K5
    Apr 6, 2000
    558
    Chicopee, Ma 01020
    Auto 700r4 tranny, and the fuel filter is on the right way. The timing is at 0 deg. That's what the underhood sticker says.
