engine trouble?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by K5Dan, Dec 8, 2002.
  1. K5Dan
    K5Dan 1/2 ton status
    Nov 15, 2002
    583
    Port St. Lucie,Fl
    when i step on gas it kind of hesitates when i get up to speed and step on it right about when it kick down samething idles real funny kind of like its not getting enough gas also heard a tapping noise could it be an exuast leak if not what else it is an 87 350 with tbi
  2. K5Dan
    Nov 15, 2002
    583
    Port St. Lucie,Fl
    oh yeah forgot the engine light came on for a minute then went back off
  3. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    If the check engine light came on you need to check for trouble codes.
    Find the ALDL plug under your steering wheel.
    Click this link:GM trouble codes for more info on how to bring up the codes and read them.
    It helps a lot to know what codes the ECM is throwing to Diagnose the problem
  4. Marshall
    Marshall 1/2 ton status
    Apr 8, 2002
    204
    LiveRmore,CA
    My 87 TBI does the same thing when it starts to get low on gas...you might wanna put some carb/fuel inj. cleaner the tbi could be dirty.
    /forums/images/graemlins/k5.gifMarshall
    31"s/350/10Bolts/208700R4
  5. K5Dan
    Nov 15, 2002
    583
    Port St. Lucie,Fl
    thanks guys i'll see what i come up with /forums/images/graemlins/confused.gif
