engine trouble
Discussion in 'The Garage' started by BabeTheBigBlueOx, Apr 27, 2003.
  1. BabeTheBigBlueOx
    BabeTheBigBlueOx Registered Member
    Aug 31, 2002
    13
    Tennessee
    I'm having problems with my 305.It is over heating very quick and it is burning lots of oil. /forums/images/graemlins/k5.gif jinxdresser@hotmail.com
  2. Topdown
    Topdown 1/2 ton status
    Nov 26, 2002
    2,598
    Vancouver, Washington, U.S.A
    not 100% on the 80's K5's but I would check my thermostat and coolant levels... if its overheating I wouldnt be surprised to see a stuck thermostat. As for the burning oil... not sure there. How many miles? Is this carbed or injected? stock engine or built/changed?
    Sorry for the questions but hoping something jumps out at me.
    -Ryan
  3. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    could also be a cracked head or blown head gasket /forums/images/graemlins/eek.gif is there any water in the oil or oil in the water? are you getting steam out of the exhaust?
  4. hardcore71
    hardcore71 Registered Member
    Nov 21, 2002
    86
    Weare NH
    In the mid-late 80's GM had problems with 305 blocks cracking in the lifter valley. This could cause your overheating/oil usage problem. Pull your oil fill cap and check for a milky goop on the underside. If it's there then you know you are getting coolant in your oil.
