Engine turns after shut-off?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Hayduke, Dec 28, 2000.
  1. Hayduke
    Hayduke 1/2 ton status
    May 9, 2000
    271
    NE Columbus, Ohio
    my rig does this every once in awhile when i use cheap gas. it has a stock 305 w/ 107K miles on it, and it burns a bit of oil too. i forget what it is called....but when i stop and turn her off the engine will chug/lurch/turn a few times, sometimes it's almost violent and scares me! would a good all-around tune up help this? is it a bad thing or is the engine not being beat up too bad? i know if i don't use cheap gas it will go away, but was just wondering. i'm a poor-ass student and with gas prices sometimes all i can fill her up with is crap gas!
    thanks!
    peace.
    HAYDUKE
    Insured By COLT, Policy #.357M
    <A target="_blank" HREF=http://haydukesk5.coloradok5.com>http://haydukesk5.coloradok5.com</A>
  2. 87chvy4x4
    87chvy4x4 Registered Member
    Jul 15, 2000
    80
    alabama
    my ol dtruck does this and my dad check it out and said it was cause i had the timing to high
    CaLeB
    RiVeR cItY oFfRoAd
    <A target="_blank" HREF=http://caleb.coloradok5.com>http://caleb.coloradok5.com</A>
  3. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    It's called dieseling.
    89 K5 Silverado
    <A target="_blank" HREF=http://mudfrog.coloradok5.com>http://mudfrog.coloradok5.com</A>
  4. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    My truck does this when it is idling high and I shut it off. I have a Edelbrock quad carb with electric choke. Eversince I had the electric choke it seems to do this when I don't drive on long trips (and very cold days). So, the carb is still warming up I guess and that means its has to idle high. Then I put it in park and shut her off and it will either make a back fire sound out of the exhaust, or the engine will make a violent sound like you mentioned. Scares me too, but I don't know if any harm is done. I would like to know though. But with my old manual choke Rochester Quad carb, this never happened. Wierd. Anyways, I think that may be why. On longer trips (after the engine has worked hard), the idles goes back to normal and this never happens with normal idle. Anyways that my 2 pennies.
    Boss
    <A target="_blank" HREF=http://www.boss.coloradok5.com>http://www.boss.coloradok5.com</A>
  5. JimmyDie6.2
    JimmyDie6.2 1/2 ton status
    Jun 20, 2000
    453
    Long Island
    check your timing, you can cause serious damage to the vehicle by letting it diesel, if the motor actually backfires your really running a risk. You could bend a valve or a pushrod, check on that timing, crappy gas could also be the problem cheap gas is igniting from the heat of the combustion chamber in addition to timing that is off, without spark. You would need to retard the timing, what this means is turn the distributor clockwise, you need to do this with a light though, to fix the timing properly.......js
  6. dyeager535
    26,975
    Easy way to solve this (and its only temporary until you get time to really find and fix the problem) is to shut the truck off in gear.
    Dorian
    My K5 and Chev/Olds links: <A target="_blank" HREF=http://yeagerd.home.mindspring.com/index2.html>http://yeagerd.home.mindspring.com/index2.html</A>
  7. Cavalry
    Cavalry 1/2 ton status
    Oct 1, 2000
    978
    upstate NY(although I cant figure out why)
    Is your truck kicking to the lowest step on the idle? On a quadrajunk its controlled not only by the choke but a vac pot on the back pass of the carb. Check also for vac leaks. This will make your truck diesel too.
  8. Boss
    2,550
    Maryland
    dyeager,
    Yeah, I forgot to mention that. Shut the truck off while in Drive, so the idle is still down.
    Now yall are saying that my timing is off, but this only happens when I drive for a short distance (when I start it up when cold) and the carb is still trying to warm itself up. Could this still be the timing? After I drive for a while or drive hard, its perfect. I knew that this could be harmful [​IMG]. Thanks for letting me know.
    Boss
  9. NYC K5
    NYC K5 1/2 ton status
    Apr 3, 2000
    185
    Staten Island NY/da bronx
    change the plugs if the plugs are too hot when you shut down the engine they can cause ignition of the fuel. also the grade of gas doesnt matter if your engine is designed for regular it runs best on regular any premium gas you put in is just a waste of money. i run econo gas or 86 octane when i find it and have no trouble.
