Engine types
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Steve the grease, May 4, 2000.
  1. Steve the grease
    Steve the grease Newbie
    May 4, 2000
    Hi there. Small blocks are few and far between here in Wales England I am buying a basket case blazer 1978 I think, theres no title. The engines obviously a V8, with a 4 barrel carb, but how do I tell if its a 302, 350, or 400 Cu inch? Where is the engine number situated? Thanks in advance for any replies.
  2. NYC K5
    NYC K5 1/2 ton status
    Apr 3, 2000
    185
    Staten Island NY/da bronx
    i was in cardiff last summer, its a very nice place. check the glove box in the U.S. all technical data on gm vehicles is in there, if not good luck all those blocks are the same phlsical size.
  3. Goose
    Goose 1/2 ton status
    1,127
    South Central Kansas
    Look at the 4th digit in your Vin#. 'U'=305; 'L'-350; 'R'=400. Unless someone swapped engines this should do it for you. To check correct year, look at 6th digit in Vin#; '3'=73; '4'=74; etc to 1980 which is 'A'
    Mud is just thick water, or is it that water is just thin mud?
  4. Eagle86K5
    Eagle86K5 1/2 ton status
    Mar 5, 2000
    974
    Whitehouse, Ohio
    Goose, my buddy my pal, my Chiltons and owner's manual shows the breakdown a bit different, I may be wrong but I have attached a copy of it from the manual, let me know if it is wrong...
    <font color=green>[​IMG]Eagle86K5[​IMG]
  5. Goose
    1,127
    Well that's correct, but for the 81 and later production with the 17 digit VIN#. The K5 in question is a '78 which uses the older VIN# coding. BTW, it wouldn't have been my first mistake.
  6. Eagle86K5
    Mar 5, 2000
    974
    Whitehouse, Ohio
    You are absolutly ...right.Actually the Chiltons manual says that but because I got a 86 I never read the fine print. Thanks for the info...
  7. jsc383
    jsc383 Registered Member
    Apr 8, 2000
    22
    Step aside amature................. i got the OFFICIAL GM 86 TRUCK SHOP MANUAL 'the bible, study it well'
    try looking on the right side valve cover for a diesel orby the oil filter or below the cylinder head for gas
  8. Eagle86K5
    Mar 5, 2000
    974
    Whitehouse, Ohio
    The word is...amateur
    and I have not been one of those in 47 years.
    I see I have to let you folks know something again, when replying to posts, go to the first post in the list and click there, not the last one in the list. By using the last one in the list, that person gets an email "reply to your post" May not be the person you meant to get the answer.....
  9. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    UMMMMMMMMMMM...............UMMMMMMMMMMMMMM.........Eagle..........It's actually spelled A-M-A-T-E-U-R. Trust me- I know because I am one(at least that's what my wife tells me)!!!!!! LOL
  10. Eagle86K5
    Mar 5, 2000
    974
    Whitehouse, Ohio
    deslexic fingers....
  11. BAMA74K5
    BAMA74K5 Registered Member
    Mar 27, 2000
    37
    Tuscaloosa, Alabama
    Correct me if I am wrong, but I think that on GM blocks the block size is located behind the distributor. It is punched on the block with the firing order. It will probably be in liters though.
    5.0L=305
    5.3L=327
    5.7L=350
    ?L=400
  12. Andreas
    Andreas 1/2 ton status
    188
    Sweden
    You can also look up the block number (6-9 digits). It´s located behind the left head, VERY hard to see when the engine still is mounted in the car and it´s usually covered with oil and dirt. Pop the valvecovers for head numbers if you feel like it, then surf to http://www.mortec.com and look ´em up.
    Andreas
    406cui of pure sh*t[​IMG]
