Engine vibrations
Discussion in 'The Garage' started by TWISTEDJACK, Oct 23, 2002.
  1. TWISTEDJACK
    TWISTEDJACK 1/2 ton status GMOTM Winner
    Jul 24, 2002
    882
    Boise, ID
    I have a pronounced vibration that starts from 1200-2400rpm. I have unhooked all of the belts and the torque convertor. The vibration gets worse as I hook each piece
    back to the motor. I can't figure this one out. I checked the harmonic balancer and flexplate both are tight. /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif
  2. 4x4k20
    4x4k20 1/2 ton status
    Mar 17, 2001
    1,699
    williamson ga.30292
    check your engine mounts and transmission mounts they may be worn out also check the bolts that hold them on they could loose also check to make sure the transmission to eng. bolts are tight
  3. TWISTEDJACK
    Jul 24, 2002
    882
    Boise, ID
    Tranny mounts are new and the bellhousing bolts are tight.
    The motor mounts look good to me. The motor doesn't move much when I pry up on the mount. /forums/images/graemlins/confused.gif
