Engine won't stop turning over.....
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Stomper, Jul 13, 2003.
  1. Stomper
    Stomper ΜΟΛΩΝ ΛΑΒΕ GMOTM Winner
    May 11, 2002
    3,767
    Iowa
    Engine won\'t stop turning over.....
    Or shut off with the key...
    Yesterday I was going to use my dads 74'K20 for moving grain. It hadn't been run for a few months but was stored inside. Tryed to start it and when I turned the key off it kept on turning over. Luckly at that time it didn't start and I got a battery cable unhooked.
    So I hooked the cable back up, no problem. Got it started and moved to where I was going to use it. Shut it down. Went to start it again and it started but the starter kept on going /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif And it wouldn't shut off with the key. Not to good for the starter /forums/images/graemlins/frown.gif Pulled the cable once more and pulled the truck out of the way. Pulled the starter today and the bushings are shot and the drive is kind of wore /forums/images/graemlins/tongue.gif. But the fly wheel looks good. My question is is the problem in the steering column or what is it? /forums/images/graemlins/1zhelp.gif Thanks,
    Brett
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    Re: Engine won\'t stop turning over.....
    probably the solenoid,...same thing happened to my buddies ferd when it got wet..old solenoid, swapped his spare in and worked great
  3. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    What a coincidence...that happened to me with the lawn mower the other day. Scared/confused the piss outta me /forums/images/graemlins/tongue.gif
  4. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Check the starter and see if the wires down there are crossed to the point of the battery cable is laying across the other post.
  5. Stomper
    May 11, 2002
    3,767
    Iowa
    It has a new power cable from the battery and the other wires are in good condition also. So I think I can cross that off the list. /forums/images/graemlins/laugh.gif thanks /forums/images/graemlins/thumb.gif
  6. Stomper
    May 11, 2002
    3,767
    Iowa
    Well it needs a new starter now /forums/images/graemlins/angryfire.gif so it will get a new solenoid. /forums/images/graemlins/thumb.gif
    Any one else have other ideas, don't want to put on the new starter and have it happen again /forums/images/graemlins/deal.gif
  7. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    even more funny on this one, a buddy of mine, his dodge cummings (think its a 98) did it to him while i was at the house. ended up being the selonoid, and battery cables. corrosion crawled doen the cable to the selonoid. 210.00 dollars later... all worked fine.
    Grant
  8. Stomper
    May 11, 2002
    3,767
    Iowa
    It was a little nerve racking to say the least /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif I had to run to my shop to get a wrench for the battery cable and I Don't like to run /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif The buildings are about 50 yards apart, up hill both ways /forums/images/graemlins/rolleyes.gif /forums/images/graemlins/thinking.gif And don't be fooled the snow is still very deep /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
    Thanks everyone /forums/images/graemlins/thumb.gif
  9. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,068
    479
    Grand Rapids area
    This happened to me once, too. Fortunately, the starter gear had retracted far enough not be in contact with the flexplate once the engine started. I too had to do some running to find a wrench, after the 5 or 10 seconds it took me to figure out what in the heck was going on.
    The problem of course is the solenoid sticking. Since I added a Ford solenoid, I haven't had this repeat or had a single hot start problem, even since I added the headers. I don't think I even replaced that starter.
  10. Stomper
    May 11, 2002
    3,767
    Iowa
    Well I got the new starter today. Put it in tonight and it works great....Thanks all /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  11. Confedneck
    Nov 1, 2002
    5,236
    ^5
