engine ?.....
Discussion in 'The Garage' started by adamforsythe, Aug 6, 2005.
  1. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    Hello,
    Well I got my truck home today. When I was reving it up I heard a pop kinda like a back fire and the truck just died. It will just turn over now. where should I start to find the problem?
    Adam
  2. 74757685k5
    74757685k5 1/2 ton status
    Nov 13, 2004
    258
    montana
    feul or ignition prolly
  3. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    Hello,
    Thats what I am thinking. I am going to tear into it today.
    Adam
  4. justwhatido
    justwhatido 1/2 ton status
    Apr 8, 2004
    1,037
    Mobile, AL
    When the fuel supply dies you rarely
    have it happen with a back fire. Usually that indicates an ignition problem. My guess is that the distributor hold down clamp was loose and the distributor has jumped timing, or you need to check the timing chain.
    Static check the timing after checking the distributor hold down clamp. I'll bet that you find the problem.
    Good luck,
  5. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    Hello,
    I did noticed that my dizzy came loose but the clamp was still keeping it from jumping up. I am starting to think that the popping I heard was a backfire because that 350 is free flowing as hell with that 2.5" duel exhuast system. I know before when I was reving it up it would back fire when the RPM started to come down.
    Adam
  6. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    I found the problem....The maine part of the dizzy killed over.
    Adam
